Did you know? 🤔
1998 V70 Leaking Transmission Fluid from Oil Cooler Connection to Radiator
StubZz
Year and Model: 1998 V70
Has thanked: 1 time
Been thanked: 0
United States of America
StubZz
Post by StubZz » Fri Aug 18, 2017 3:30 pm
Hello All!
I am new to this site, but I've come here before and seen some helpful threads!
My '98 V70 was leaking a lot of coolant recently, I decided to take it to a shop nearby that specializes in radiators and mufflers. After the replacement it was all good for a few days. Then it started leaking transmission fluid from the bottom transmission oil cooler hose connection. It is a slow leak, so I'm not too worried about it as of now. It was not leaking before the replacement. After the replacement the guy that worked on the car said we should get some new transmission cooling hose retainers, as the old ones were incredibly corroded (https://www.fcpeuro.com/products/volvo- ... er-6842411 <-link to the part on FCPEuro, part number is 6842411). I've also driven the car around for 30 minutes and checked the fluid oil (as per the instructions in the owners manual) and the fluid was at the max line if not above. Will the leak resolve itself after the fluid level has reached the max line, is it a problem with the radiator itself, or will putting the new retainers on resolve it?
Thank you for any help you will provide, it means a lot to me! :D
~StubZz
tryingbe
Year and Model: None
Has thanked: 0
Been thanked: 23 times
tryingbe
Re: 1998 V70 Leaking Transmission Fluid from Oil Cooler Connection to Radiator
Post by tryingbe » Fri Aug 18, 2017 3:53 pm
85 GLH, 367 whp
00 Insight, 72 mpg
StubZz
Has thanked: 1 time
Been thanked: 0
StubZz
Post by StubZz » Fri Aug 18, 2017 3:55 pm
Replace them all.
https://www.fcpeuro.com/products/volvo- ... 0-6842411k
Alright, thank you!
Has thanked: 12 times
Been thanked: 211 times
Canada
Post by scot850 » Fri Aug 18, 2017 4:35 pm
Also be careful when fitting the hose retaining cage. They are orientated. If fitted the wrong way around they will leak and can blow off as a friend of mine found out the hard way!
Also, some cooler hoses not have 2 'o' ring seals not only one?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
StubZz
Has thanked: 1 time
Been thanked: 0
StubZz
Post by StubZz » Fri Aug 18, 2017 5:44 pm
Alright, I will be careful with that! I am not sure about the 'o' rings, I believe it is one set for both though.
brunocerous
Has thanked: 49 times
Been thanked: 7 times
brunocerous
Post by brunocerous » Sun Sep 17, 2017 5:33 am
How did the cooler line replacement go?
I've been getting the same quarter-size fluid stain on our driveway since doing a drain-and-fill, and yesterday located the culprit: Leaking transmission cooler hoses where the rubber meets the metal crimp.
It's been getting worse, so I've got another project ahead of me!
2004 XC90 AWD
1998 V70 T5, AT, project
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
StubZz
Has thanked: 1 time
Been thanked: 0
StubZz
Post by StubZz » Fri Dec 08, 2017 12:05 am
It went fine! I now have no transmission fluid leaking!
