IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
My 96 850 Turbo Wagon idles fine but dies with any load
Luke.T5R
Year and Model: 1995 855 T5R
Re: My 96 850 Turbo Wagon idles fine but dies with any load
Post by Luke.T5R »
I'll buy a fuel pressure gauge and check it when I get it reassembled. currently the intake is off of the car and I'm changing the PCV system. It needed done and I suspect it could be part of the issue. The car supposedly got a new fuel pump and fuel pump relay in 2015.
Chuck W
Year and Model: 97 854 T5
Has thanked: 28 times
Been thanked: 69 times
Post by Chuck W »
Luke.T5R wrote: Thu Aug 31, 2017 2:44 pm The car supposedly got a new fuel pump and fuel pump relay in 2015.
They could've skimped on the fuel line, or ham-fisted the install. Mine had been "fixed" by a PO also---
'97 854 T5 - Manual Swap, M4.4,COP, P2R Brakes, 16T, chassis bracing, XC70 nose swap
'97 855 GLT - Hers. RN swap/16T/exhaust/302s/Flashable M4.4, chassis bracing, 2 kid seats
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
I had almost the exact same problem in my 1994 850 non turbo.
Bottom Line: Take off the rotor cap and inspect it for foul play. U can leave the spark plug wires attached. Its just three 10mm bolt/screws and I think three more 15 torx or 20 torx screws. The bolt securing the plate to the camshaft is also 10mm.
Granted, it's still pending to be road worthy, it now drives. After a new MAF sensor, fuel pump, and everything inbetween. Vacuum and fuel lines double checked it was just the rotor. My bolt securing it to the camshaft was broke and it fell out inside the cap.
Not sure how it even idled. But I drove it 50 miles on the freeway, almost home, before it would not accelerate anymore.
Hopefully on yours the bolt may just been loose.
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
rspi
Has thanked: 22 times
Been thanked: 50 times
Post by rspi »
Where did you get the MAF? What brand is it?
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
rspi
Post by rspi »
Reys
Year and Model: 850T estate '96
Post by Reys »
I had the same issue a year ago. After swapping every sensor and part I could think of I finally opened the fuel pump and had the exact same slipped hose like Chuck W. The nipple isnt ribbed and the oetiker style clamp with hose will slip down over time. Access is easy in a wagon takes 20min. Worth a look.
