IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Handbrake dash warning light won't go on Topic is solved
harojs
Year and Model: 850, 1996
Post by harojs »
1996 850 Wagon
- BRAKE bulb DOES light during pre engine start cluster bulb test
- BRAKE bulb DOES light when brake fluid level sensor removed
- BRAKE bulb DOES NOT light when handbrake engaged
- Handbrake continuity switch checks OK
- Grounding Handbrake yellow wire to chassis DOES NOT light bulb
Any ideas? Seen this before?
I can't find a good circuit diagram to chase the yellow wire route up from handbrake switch
Is there a computer reset required somehow?
-John
Bellevue, WA
[email protected]
p.s. - sorry just saw there was a previous post on this topic - oh well, maybe that will help get noticed
harojs
Re: Handbrake dash warning light won't go on  Topic is solved
Post by harojs »
OK - FIXED
There are TWO break warning bulbs in the dash - BRAKE and PARKING BRAKE
I had assumed the BRAKE bulb was for both the break fluid level and the parking brake, and I started down the path to debug the switch on the hand break and got wrapped around the axle.
Since the PARKING BRAKE was not lighting up on start check, I didn't see it light up, and so did not remember there are two bulbs.
Hopefully, someone will find this post if it happens to them.
Thanks for watching - John.
