Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
convince me it's worth fixing my headlight wipers (98 S70) Topic is solved
utilityaudio
Year and Model: '98 S70 GLT
Has thanked: 32 times
Post by utilityaudio »
Last night after leaving work, I found my passenger side wiper hanging from the hose on my '98 S70, and I'm debating whether or not I care enough about it to actually replace it instead of just deleting the visible broken parts and plugging the hose.
looks like I can get parts to replace the arms,wipers, heads, and Blades for both sides for about $60 from iPD.
I guess maybe I should start by determining if the Headlight wiper motors still work, because I really don't think that I'm willing to shell out over $200 to fix something that can be broken again the next time an SUV backs into me while I'm parked on the street.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 28 times
Post by j-dawg »
It's not.
wizechatmgr
Has thanked: 27 times
Been thanked: 78 times
Post by wizechatmgr »
If you live in the north (or anywhere that gets a lot of snow and salt) then I'd suggest it.
Otherwise, I'd just remove the arms and call it a day.
1999 V70 XC AWD 2.4 T -- ~201k miles
1998 V70 2.4 NA -- ~180k miles
thebull
Year and Model: XC90 R-Design 2009
Post by thebull »
Get everything from some junkyard or eBay. Otherwise it`s too expensive.
Cheers
Flying on 2009 XC90 R-design 3.2L AWD and 2006 XC90 2.5T AWD. Volvo owner forever.
RickHaleParker
Been thanked: 808 times
Post by RickHaleParker »
I replace both headlight wiper motors on my '98 C70. The one on the left side is easy to replace ( drivers side on left hand drive cars), the one on the right side takes some time to do because you got to take a lot of stuff off to get to the motor.
If you to pull used motors, here is a tip, the left and right wiper motors are identical. However to use a motor pulled from one side of the car on the other side of the car, you need to open the back of the motor and shift the internal transmission of the wiper motor .. so the arm will turn the correct direction.
Last edited by RickHaleParker on Sat Oct 07, 2017 7:50 am, edited 1 time in total.
JRL
Year and Model: Several
Been thanked: 13 times
Post by JRL »
Don't bother.
Contact info for purchases: jrl1194@aol.com
Has thanked: 597 times
Been thanked: 1693 times
Just remove one of them and then tell people one-wipered cars is a new thing.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
wizechatmgr
Go to Wal-mart purchase one of those packs of googly eyes, now place one on the car on the headlight where the wiper setup is basically dead. Tell them the car has been improved with "A EYE" and watch them think you now have artificial intelligence in the car. Sit and watch in wonder as they all want to drive it and figure out what it does. Ask them if they noticed any additional power... Some will.
For the record, I'm the same guy that has previously placed notes on paper towel dispensers at the job (typically manual, some motion activated) that say it's now voice activated... I'm also the guy that noticed some of the signs near the elevators showed the person running towards the fire rather than away from it. That wasn't my work. Never anything dangerous...
Has thanked: 157 times
Been thanked: 449 times
Post by erikv11 »
In the words of a wise man, a seer: It's not.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 135k
gone: '96 NA 850 210k, '98 NA V70 182k, '98 S70 NA 225k
mrbrian200
Has thanked: 7 times
Been thanked: 82 times
Post by mrbrian200 »
I just have the high pressure headlamp washers (not with wipers) and I'm thinking about placing some sort of in-line switch so I can turn the HP pump off during the summer. It works great for clearing salt spray during the winter but in summer it does nothing to clear bugs and just amounts to excessive/unnecessary washer fluid use. I would imagine the headlamp wipers tend to mostly just smear them around. I was used to getting through an entire spring/summer/fall season on 1-2 gallons of washer fluid on my old car. On this one with the headlamp washers it's more like a gallon/month.
