Did you know? 🤔
Is there a torque value for 4 x lower dash bolts? (VETTED ANSWER 8 Nm) Topic is solved
Has thanked: 12 times
Been thanked: 211 times
Canada
Post by scot850 » Sat Dec 02, 2017 5:17 pm
I am now re-fitting the lower dash section having repaired the broken mounts.
I have watched Roberts video on repair and in it he throws out a torque for the 4 x bolts on the firewall mounts of around 10 ft/lb.
Is there an actual torque value these bolts should be tightened to? Can't find a reference in my Vida, but then it doesn't let me read all the repair instructions in some sections for some reason.
Thanks,
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Re: Is there a torque value for 4 x lower dash bolts?
Post by abscate » Sun Dec 03, 2017 9:11 am
Interesting that all data does not report these.
DO NOT USE a standard M6 torque which is designated for metal on metal fasteners though.
I think I would firm them up to Contact, then see if my dash squeaks , before any more torque is applied
Link To Volvo Glossary
Canada
Post by scot850 » Sun Dec 03, 2017 10:15 am
I took them to 10 ft/lb as Robert suggested. Problem always is finding the middle ground on these as if it is not enough then the wipers and cover all have to come off again. I guess you could drive the car without those on to check it out now I think on it.
2006 XC70
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 4 times
Been thanked: 12 times
United States of America
Klausc
Post by Klausc » Sun Dec 03, 2017 10:48 am
Too late for a helpful hint: Have someone push the dash forward from inside the car until the bolts are snug. If you try to pull the dash using the bolts, it will still be too loose. Been there, done that.
Klaus
Canada
Post by scot850 » Sun Dec 03, 2017 12:34 pm
Good suggestion. I did push the dash with one hand while turning the wrench with the other. Feels tight but I am concerned that even 10ft/lb might be too much. Dash feels incredibly solid for now. I've dropped a note to the dealer foreman I know to see what they recommend too. Hopefully get a response tomorrow.
Thanks for the suggestion.
2006 XC70
Canada
Post by scot850 » Tue Dec 05, 2017 11:13 am
And here is the correct answer direct from my Volvo foreman friend Bill. 8Nm is the correct torque value for the 4 x dash mounting bolts in the firewall behind the wiper motor.
2006 XC70
Klausc
Klausc
Post by Klausc » Tue Dec 05, 2017 11:57 am
Heck, I wouldn't trust my torque wrench to register 6ft/lb. That is just barely over 'finger' tight. I wouldn't loosen your bolts.
Klaus
Canada
Post by scot850 » Tue Dec 05, 2017 3:22 pm
I have a Toque wrench with a range of 0-30Nm on a 1/4" drive and a 0-50Nm on 3/8" drive so I am ok for this. 10ft/lb is nearly 80% too high.
2006 XC70
Trinidad & Tobago
Re: Is there a torque value for 4 x lower dash bolts? (VETTED ANSWER 8 Nm)
Post by abscate » Wed Dec 06, 2017 7:15 am
Added vetted answer to title for brevity
Canada
Post by scot850 » Wed Dec 06, 2017 8:03 am
Thanks abscate.
2006 XC70
