Did you know? 🤔
1995 855, wheel guide pin borken off
RickHaleParker
Has thanked: 3 times
Been thanked: 433 times
United States of America
RickHaleParker
Re: 1995 855, wheel guide pin borken off
Post by RickHaleParker » Mon Dec 11, 2017 9:43 am
So, we assumed that old guide pin was already out ? Then we use tap to clean up the thread ?
Correct, except we don't assume that old guide pin is out. The old guide pin is out when you do follow and chase. When your finished with that, you can do your stalking without hindrance. :wink:
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
lcc014
Year and Model: 855, 1995
Has thanked: 0
lcc014
Post by lcc014 » Mon Dec 11, 2017 12:33 pm
Got it, thank you :)
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Dec 11, 2017 12:42 pm
One more tip, soak it good with liquid wrench and use a left hand drill bit. You might get lucky and the broken part will back out as the left hand drill bit bites. That how I got a broken head bolt out of a Volvo 2.9.
Has thanked: 80 times
Been thanked: 243 times
Post by erikv11 » Mon Dec 11, 2017 7:39 pm
Right - see post #3. :D
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 15 times
Been thanked: 21 times
Eddystone
Post by Eddystone » Tue Dec 12, 2017 6:37 am
While the guide pin is not strictly necessary, it makes reinstalling your wheel a real hassle. I know because I have a broken pin.
Someday, I will get the sheared off pin out of the hub. In the meantime, a guy at my local tire store gave me a little aluminum tool that is basically a rod with the appropriate threads on one end. You screw this into any lug hole after aligning things, install the wheel and remaining lugs, then remove the tool and replace the last lug. Easy peasy.
If you can't get this special tool, just get a long bolt with the correct threads and cut the head off. It will function in the same manner. You could bring one lug from your car into your local hardware store and match up the size and threads to something at the store.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
gmh
Year and Model: 97 850 R Wagon
Has thanked: 11 times
Been thanked: 15 times
gmh
Post by gmh » Tue Dec 12, 2017 5:05 pm
[quote=Eddystone post_id=457138 time=1513085869 user_id=67572]
... a guy at my local tire store gave me a little aluminum tool that is basically a rod with the appropriate threads on one end. You screw this into any lug hole after aligning things, install the wheel and remaining lugs, then remove the tool and replace the last lug...
IPD sells the one in the link below for the P2 and P3 cars (and used to sell one for the 850s as well), a little steep and a bolt may work as well.
https://www.ipdusa.com/products/11713/1 ... tall-guide
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-present)
2014 XC60 T6 (2017-present)
lcc014
Has thanked: 0
lcc014
Post by lcc014 » Tue Dec 12, 2017 8:05 pm
I have a similar guide pin for my BMW. BMW has no guide pin and this tool make it easy to put back the alloy wheels.
Eddystone
Eddystone
Post by Eddystone » Wed Dec 13, 2017 1:38 am
Yup. Looks very similar to that, but mine is aluminum alloy. The key bit of info from the IPD listing is the thread:
M14 X 1.5 THREAD PITCH
Now, we know what size bolt to buy and grind the head off of. ;-)
1993 945 Turbo/Auto
Has thanked: 267 times
Been thanked: 846 times
Trinidad & Tobago
Post by abscate » Wed Dec 13, 2017 4:34 am
This will cost a bit more if you buy it in stainless but then cutting the head off will be easy. Chase the thread with a nut when done, then tape the end with car colour matching tape
Can't wait to do this, great idea!
Link To Volvo Glossary
