IPD sale XeMODeX - Experts in Volvo Electronics
MVS-Amazon link helps MVS!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Radiator Fan Speed, When it Should Run
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 51 times
Been thanked: 201 times
Post by bmdubya1198 »
A post in my last thread got me thinking about if my fan is not running in its low speed. I have been doing extensive troubleshooting over the past couple weeks on my car's "hiccup," and I've pretty much got it down to the cam sensor connector being rather disintegrated. Could also be the MAF or voltage regulator, but I'll leave that for another thread if I can't figure it out. I'm just relieved all of my wiring has tested good. However, my fan jumping immediately to high speed might still be causing this drop in RPM.
When I turn on my A/C, the fan doesn't kick on. IIRC, it's supposed to, whether the engine is hot or not. I tried it on my cousin's 1999 S70, and his fan didn't kick on either, but at the time both cars were cold. Maybe that was the issue, but I wanted to confirm that.
Otherwise, when is the fan supposed to be running at its high or low speeds? The only time I notice the fan running is when I get home and I let it idle for a couple seconds, and it is always on what I assume is the high speed. I have never noticed it running on the low speed.
How do I know the fan is functioning correctly? What I wanted to accomplish with this thread is a "list" of when the fan is supposed to be on low and when it's supposed to be on high for troubleshooting purposes. This seems like it should be straightforward, but I haven't found anything online about this.
Maybe I just need to replace the fan relay... who knows. I replaced it with a junkyard relay after buying my car since it never had one to begin with (it was wrecked). ECT tested good and the thermostat is only a year and a half old. My temp gauge reads normal, so no concerns about the fan not cooling sufficiently.
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
bmdubya1198
Re: Radiator Fan Speed, When it Should Run
Checked if my fan came on with my A/C today while the engine was at operating temperature, and it did not. The compressor kicks right on and my A/C was cold, but the fan didn't turn on.
It came on a minute or so later on high speed, but that was because of the engine temperature, I think.
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 38 times
Been thanked: 45 times
Post by ecbsykes »
bmdubya1198 wrote: Fri Mar 23, 2018 2:21 pm Checked if my fan came on with my A/C today while the engine was at operating temperature, and it did not. The compressor kicks right on and my A/C was cold, but the fan didn't turn on.
I had a similar issue with the fan not working with the AC on (as it should). Replaced the fan relay and all was well. Hope your solution is that simple!
2000 V70XC - 308,000 miles as of 17 Dec 2020
bmdubya1198
That is reassuring. I’ll have to grab one next time I’m at the junkyard. Unfortunately it’s supposed to be raining all weekend.
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 21 times
Post by esl_97_850_T5 »
A '98 V70 GLT presumably has a Motronic 4.4 ECM.
volvo850diag v0.8 can issue M44 test commands to:
- run fan on high, or
- run fan on low.
A summary of how to use volvo850diag to test the '98 V70 GLT fan speeds:
- Download latest volvo850diag.zip.
- Unzip with WinZip, 7-Zip, etc (not with Windows Explorer).
- Get it setup (using instructions in its readme and in the "local" volvo850diag.html extracted from the .zip).
- Run the "local" volvo850diag.html with IE.
- Click "Options", then change "scanner_type", if necessary, then click "Save" (if option was changed).
- Click "Start Realterm" to get your ELM327 device connected to your car.
- Click "Read All DTCs" and let it run to completion.
- The ECU 7A Setup button should now be one of the enabled buttons.
- Click ECU 7A "Read DTCs" (and wait a few seconds).
- Underneath volvo850diag's line of ECU 7A buttons, there is a pulldown labelled
"Select item for M44 to test/control" (or something similar). It should now be enabled.
- Select either one of these from that "Select item for M44 to test/control" pulldown:
* Engine Coolant Fan, High (full speed)
* Engine Coolant Fan, Low (half speed)
- Click Test.
- Listen to the fan speed as the fan cycles on and off 3 times.
- Select the alternate fan speed, click Test, then listen to its different fan speed as it cycles on/off.
That's one way to see/hear the different fan speeds on '96-'98 850/S70/V70/C70/XC70.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
bmdubya1198
esl_97_850_T5 wrote: Fri Mar 23, 2018 6:30 pm A '98 V70 GLT presumably has a Motronic 4.4 ECM.
- run fan on low.
- Click Test.
I figured there had to be some type of way to activate it manually. I'll give that a try this weekend if I can get my bluetooth ELM327 adapter set up right. Thanks for posting this!
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
BlackThunder
Year and Model: 1997 850
Post by BlackThunder »
- run fan on low.
- Click Test.
Will this work on 1997 850? I'll have to see if I can get my computer to hook up to my ELM 327 too. Please let me know if someone gets this to work with their Windows or Mac. I have Torque but it can't do this stuff, I don't think. Can it?
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
esl_97_850_T5
Dustin,
1. If your 1997 850 has a Motronic 4.4 ECM (with factory software), then the commands very likely will work (though I have not tested that, since my '97 850 T5 did not have a M44).
If your 1997 850 has a Motronic 4.3 (with factory software), then the commands will definitely *not* work (since there is no ECU 7A).
If your 1997 850 has an M4.4 ECM which has been flashed by someone, thereby overwriting the M4.4 software installed at the factory, then you'll have to ask the question to whoever wrote that updated M4.4 software.
2. I have gotten it to work with WinXP, Win7, and Win10 (for my '98 S70 GLT).
3. I don't think Torque can do this.
BlackThunder
Good info. Thank you.
Dustin
Dustin
2013 Volvo C30 T5
esl_97_850_T5
Testing the radiator fan of 96-97 850 / 97-98 S70/V70/C70/XC70 whose ECM is Motronic 4.4 -- by forcing the fan on High or Low for a short time -- can also be performed by xiaotec "850 OBD-II" Android app V1.1.6. Presumably the more recent "850 OBD-II" versions also have the ability to control the radiator fan on 96-98 850/SVC70 with M44.
