Can someone kindly tell me the different sizes and amounts of vacuum hose for a 1998 V70 GLT 2.o liter.
Have a coolant leak and cannot find it, driving me bonkers! Going to replace all the radiator hoses and turbo hoses and thought I may as well do the vacuum hoses at the same time.
thanx,
Endangered
Vacuum Hoses
- Year and Model: 1998 v70 GLT
Can someone kindly tell me the different sizes and lengths of vacuum hose for a 1998 V70 GLT 2.0 liter. Lots of diagrams showing what goes where but am having a difficult time finding the different hose sizes and lengths.
Have a coolant leak that I cannot find and it's been driving me bonkers. Going to replace all the radiator-heater hoses along with the turbo hoses. Thought I'd do the vacuum hoses at the same time.
thanx,
Endangered
thanx,
Endangered
- Year and Model: 1996 850 T5
- Has thanked: 55 times
- Been thanked: 38 times
Your best option, unless you want to get a pre-made kit, is to buy silicone vacuum hose in 4, 5 and 6 mm, and cut to length. Swap out one at a time, and be careful with routing to things like TCV and those things. Getting to the ones on the turbo is the worst part, but with patience and long, thin fingers, it's mostly just going slow and steady.
If you're doing the brake booster vacuum line as well, use 8 mm (I think) ID reinforced fuel hose. That hose MUST NOT be something that might collapse in a do or die kind of situation.
- S
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Thank you ....How much of each size is needed??
- WhatAmIDoing
- Year and Model: 1998 S70 T5M
- Has thanked: 66 times
- Been thanked: 57 times
I believe I read somewhere that 12ft of each is enough, but I cannot confirm.
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out
Knows enough to be dangerous
- 2548 Views
Last post by erikv11
- 16 Replies
- 1897 Views
Last post by southofmotown
- 553 Views
Last post by tanelus
- 15 Replies
- 2236 Views
Last post by Rsokk
- 533 Views
