855 2.5 20V permanent open loop..
mateuszek
Year and Model: 855 2.5 20V 1997
Post by mateuszek »
Hello
I'm already fighting a bit, that's why I decided to make a separate topic here.
Right to the point.
patient 850 2.5 20V 170HP 1997
Front Lambda sensor - NEW (original bosch according to No.)
Rear Lambda NEW (original bosch according to No.)
symptoms:
permanent OPEN LOOP even when engine is very hot.
The values ​​of the front lambda probe are completely weird, they change when adding gas, but they stand at idle at odd values ​​(from -1.748 to 0.334 etc.)
The other thing is that the engine works very well, nothing interrupts, does not smoke, even the lambdas light does not illuminate (but in the computer VOL-FCR it is a mistake) burning gasolin may be a little bigger, but not spectacularly ..
Please help, I do not know what to look for anymore.... no one what I know, cant help me..
misha
Has thanked: 59 times
Been thanked: 163 times
Re: 855 2.5 20V permanent open loop..
Post by misha »
Did you disconnected negative battery cable after o2 sensors replacement,in order to reset fuel trim?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mateuszek
Post by mateuszek »
yes, I disconected battery for +- 10 minutes, and still nothing
misha
Post by misha »
Try to do that overnight,alowing engine to cool down and re-connect when engine is cold.
After that....drive it normaly alowing it to warm up and it should be ok.
Other than that...you might have leak at flexy pipe(between exhaust manifold and cat),vacuum leak,dirty Maf sensor,ect out of spec.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mateuszek
Post by mateuszek »
ok, today we switch MAF sensor from my friends the same volvo, and nothing, the same problem.
But today I saw stranger thing on computer.
when the engine was a little colder (arround 70-80 degresese C) it was that:
and when it was a liitle warmer:
maybe is that a water temperature sensor? I know that comp display correct temperature, but who knows....
misha
Post by misha »
Is that android app?
It could be that it is throwing wrong data.
What engine management your car have...Motronic 4.4 should be the only one in '97.
If so....you have no egr...you have sas system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mateuszek
Post by mateuszek »
no, iphone's "car scanner"
misha
Post by misha »
It can't be trusted.
VOL FCR should be used or a good code scanner which displays live data.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
