Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link
Buy your stuff using this and it helps MVS!
96 850 ac issue
- Year and Model: 850 1996
- Has thanked: 0
- Been thanked: 0
96 850 ac issue
My 96 850 AC works and blows cold, then quits. I turn it off for a minute or two then turn it back on and it works for awhile. I sometimes can get it to come back on by turning the switch to auto. It can work all day and then some days turn on and off many times. Does this appear to be the thermal switch acting up?
Thanks
2forty
Thanks
2forty
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 229 times
- Been thanked: 757 times
Re: 96 850 ac issue
The classic Volvo intermittent AC is caused by clutch gap wear. You can measure this and fix this cheaply by searching this Forum for ‘ bread clip fix’ or ‘ zip tie fix’
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
- Year and Model: 1996 850 turbo
- Has thanked: 0
- Been thanked: 5 times
Re: 96 850 ac issue
I got a couple of seasons out of the wire fix, then had to replace the compressor. It was the original, of course.
- oragex
- Year and Model: S60 2003
- Has thanked: 89 times
- Been thanked: 210 times
Re: 96 850 ac issue
If the gap is the issue, just remove the pulley (replace the bearing at same moment, use only a good brand) and remove one or two shims. There is no need to replace the whole compressor. Of course, the compressor may go bad for other reasons which will require replacing it, but for the gap issue just undo the pulley.
- Has thanked: 0
Re: 96 850 ac issue
I was never fully convinced it actually needed replacing, I'll never know now. All good until this summer, now less cold than last year, so something is up again. But just doesn't blow cool enough, no gap related symptoms. The OP sounds like a clutch-gap problem, yes.
Re: 96 850 ac issue
22 years is pretty good evaporator life if you haven't replaced it.
200-300 in parts, 10 hours stupid labor...beautiful cold AC
- Clemens
- Has thanked: 73 times
- Been thanked: 40 times
Re: 96 850 ac issue
OP, I´d start with the ziptie fix. You just need a few zipties of different size and thickness to finetune. And a feeler gauge.
If that fixes it, you can keep the zipties (I´ve had them in 2 of my cars for 2 years or so w/o problems) or reshim the clutch orreplace the compressor. If that doesn´t fix it (or the gap is within specs to start with) you might be low on R134 (refrigerant). Then I´d have a shop evacuate the system and check how much gas is left inside (after 2 years I had 400 grams inside, should have been around 750-800). Then refill and see if the AC works accordingly. If you lose the gas quickly you will need a new evap as abscate suggested.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
91 240 shifting issue/fuelpump issue
by Vancethevolvo » Sun Mar 27, 2016 11:04 am » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 0 Replies
- 372 Views
Last post by Vancethevolvo
2004 T5 C70 aerial issue ( not the normal issue )
by NathansC70 » Sun Apr 07, 2019 2:05 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 14 Replies
- 564 Views
Last post by NathansC70
Fri May 17, 2019 6:33 am
95 Volvo 850 GLT starting issue
by BlackyChan91 » Thu Dec 10, 2015 8:46 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 2 Replies
- 425 Views
Last post by BlackyChan91
Mon Dec 28, 2015 8:35 pm
96 850 R pcv issue?
by Clemens » Mon Dec 14, 2015 6:36 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 6 Replies
- 578 Views
Last post by Clemens
Mon Dec 14, 2015 11:58 am
