heat shield above muffler Topic is solved
Clemens
Has thanked: 112 times
Been thanked: 59 times
Post by Clemens »
the heatshield above the muffler came loose and is rattling. grrr! i saw a rusted off bolt falling from top off thw muffler as i shook it. is that heatshield necessary? if not, has anyone removed it without removing the exhaust? my exhaust is still good so i'd like not too touch it too much
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
SuperHerman
Been thanked: 177 times
Post by SuperHerman »
I had a similar problem on one of my old Volvos. If it is only one spot, you can try replacing with new hardware and a large washer.
If it is too far gone, what I did was coat the heatshield where it contacts the exhaust with high temp RTV and also put some on the exhaust for good measure. This is used to create a cushion to prevent rattle - high temp RTV will survive the heat and I had it lying around. I actually used an old tube that was dried up near the tip and just cut it open and applied with a gloved finger. Put it to good use before the trash. Then I used some scrap copper wire 4-5 feet in length from some Romax electrical cable, with the plastic shielding removed, and wrapped it tight around the exhaust and heat shield. Took another piece and came back the other direction. It has held up without rattle or issue for three years per the current owner.
Some have pulled it without issue, but it is there for a reason.
Has thanked: 22 times
Been thanked: 309 times
Just think ABS module................
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Rattnalle
Has thanked: 20 times
Been thanked: 124 times
Post by Rattnalle »
My front one came loose. Though it came loose in all fittings. I just removed it and drove on. It could be pried out with a bit of finesse and a bit of force.
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 32 times
Been thanked: 56 times
Post by xHeart »
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
Clemens
Post by Clemens »
scot850 wrote: Mon Sep 24, 2018 11:39 am Just think ABS module................
resolder the pins? interesting approach. I'll let my indie burn himself. :-)
in the meantime I will try rtv.
Summer: 1996 855 R
Donor: 1995 854 10V
Rattnalle
Post by Rattnalle »
SuperHerman wrote: Mon Sep 24, 2018 10:55 am I had a similar problem on one of my old Volvos. If it is only one spot, you can try replacing with new hardware and a large washer.
If you strap it to the exhaust a big part of the reason, the distance between them, is gone.
I drove 40' km or so without mine and didn't notice a difference. Perhaps it does more good in hot climates though.
SuperHerman
The proper repair would be to rip out the interior, drill out the studs and replace them as well as the shield. Too much work and the fuel tank may be there. Not sure on OP's make, model and layout.
OP post a picture of your issue and maybe a crafty solution can be developed.
From what I have read, and I don't know if it is correct, these shields are there to protect the under-body from heat damage which may occur if the car is left running for too long with limited (no) air flow. In this case, if the above picture is correct, it looks like the gas tank is there.
Clemens
Post by Clemens »
it is a 96 R. the gas tank is behind the rear axle. the muffler and shield are in front of the axle, right under the rear seat. as of now the rtv is drying. tomorrow i will take it for a spin and see if that did the job. otherwise i might try again with way more rtv. if that doesn't help i will have to use my indie's lift and his skills to take off the exhause and weld it back on. or finally go big and get a TME exhaust and maybe a downpipe...
Summer: 1996 855 R
Donor: 1995 854 10V
xHeart
Post by xHeart »
