IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
No power after braking Topic is solved
Year and Model: 850, S/V70, 06 S60R
Has thanked: 124 times
Been thanked: 351 times
Re: No power after braking  Topic is solved
Post by erikv11 »
Semi truck trailer? Forklift? :D
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 55 times
Been thanked: 37 times
Post by Sommerfeldt »
:D :D :D
No matter what, cleaning stuff is always a good idea. :)
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Cammer
Year and Model: 1996 Volvo 850
Post by Cammer »
Problem solved! I replaced all the vacuum hoses and fittings (some quite brittle). Problem persisted. I vacuum tested the MAP sensor -ok. Heat tested the Intake Air Temperature sensor - ok. I went back to the fuel system again (had already replaced the filter and checked pressure at the rail. Began with the pump - couldn’t hear it. I jumpered and bypassed the pump relay. Could hear the pump functioning! Replaced the old intermittent relay with one from inventory - the car is running like a champ. Thank you all for sharing your experience and expertise in helping me get back on the road!
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 57 times
Post by WhatAmIDoing »
Cammer wrote: Fri Nov 02, 2018 2:32 pm Problem solved! I replaced all the vacuum hoses and fittings (some quite brittle). Problem persisted. I vacuum tested the MAP sensor -ok. Heat tested the Intake Air Temperature sensor - ok. I went back to the fuel system again (had already replaced the filter and checked pressure at the rail. Began with the pump - couldn’t hear it. I jumpered and bypassed the pump relay. Could hear the pump functioning! Replaced the old intermittent relay with one from inventory - the car is running like a champ. Thank you all for sharing your experience and expertise in helping me get back on the road!
Those pesky fuel pump relays will get you. Always test the relay before you start tearing things apart and replacing things. I learned that the hard way.
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
Post by erikv11 »
Eh, totally worth it to replace all of the brittle vacuum lines, no harm done there. Otherwise he just tested things, smart moves all.
Cammer, glad you solved it! I had a fuel pump relay die on me this morning, too ...
'96 855 NA, 145k
'06 S60 R, 167k
