98-99 V70 S70 Engine Mounts. What's the 411?
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 33 times
Been thanked: 29 times
Post by Eddystone »
Could I get the general 411 on engine mounts for these car, please. I have a 98 V70 that clunks a bit going into reverse.
The lower right mount seems pretty easy to change. How about the others?
Do you replace these as a maintenance issue, or only after failure?
How easy is it to see and tell that each type of mount is bad?
Which ones are common failure items?
Which are ones that don't fail frequently but probably need to be done on a car with 150k miles?
Thanks for any general info you can provide. It's damn cold here right now, so I'm not rushing out to do this.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
Has thanked: 22 times
Been thanked: 309 times
There are 3 usual suspects:
1) Top Torque mount. This is a bit more challenging on a 98 as they are a press fit at the top of the engine. Sits about the middle top rear of the engine with a metal frame running back to the bulkhead. Usually the first to go. Check for rips/tears in the rubber.
2) The engine mount on the RH end of the engine under the crank pulley is the next to go. Place a piece of wood under the oil pan toward the RH end of the engine and gently jack the engine and watch to see if the rubber pad and metal section have separated.
Both of these will give you a bigger clunk.
3) The lower torque mount under the front center of the engine block. 2 bushes here. Both fail.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Eddystone
Post by Eddystone »
Thanks, Neil!
1993 945 Turbo/Auto
