Volvo 850 power loss under hard acceleration Topic is solved
- Year and Model: Volvo 850 T5 1993
- Been thanked: 2 times
Re: Volvo 850 power loss under hard acceleration
I feel like boost goles Up ando then goles down a bit And remains a bit low, what can cause this?
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 68 times
- Been thanked: 43 times
Boost leak would cause that sort of thing. TCV is a good place to start, as you said. Also check the vac lines on the turbo housings - I had two split here just last month.
- Has thanked: 129 times
- Been thanked: 362 times
Other very common causes of boost leak:
- the 20 year old hose on the IAC is cracked somewhere in it
- the 20 year old CBV diaphragm has hit the end of the road, too many flexes, look for actual holes (can see light through it) or lots of cracks where it flexes. Can be tested with a vacuum tester / brake bleeder.
- Intercooler path. So many hose/pipe junctions.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
i did check all of that everything is ok, nothing leaking.
the boost is half way the white line every time till 5500 rpm then goes 3/4 white line.
- 201 Views
Last post by Jaumme
- 26 Replies
- 754 Views
Last post by misha
- 137 Views
Last post by Hardtofool
