Amazon Black Friday deals
Early & late 850 instrument cluster compatibility Topic is solved
misha
Has thanked: 63 times
Been thanked: 166 times
Re: Early & late 850 instrument cluster compatibility
Post by misha »
I found one from '98...but is a 10v car.
https://www.vindecoder.pl/YV1LW5102W2502993
Scroll down for decoded VIN.
Will it work in 20v car?
I know that U.S market didn't had 10v cars....but i hope that Canadian or Australian members could help me out with this.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
I found and installed s,v70 cluster into my 850 today.
Everything works....but SRS light won't turn on with key in posII along with all other little lights.
I thought...ok....burnt bulb....replaced the bulb and it still won't come on.
Checked for SRS codes and got code SRS-127(SRS warning lamp OC or SC to ground).
Looks like somebody tried to mask the problem with SRS(deployed airbags or something).
So....my question is.....can this code prevent the airbags from functioning?
If it does....i'll remove the cluster(again) and take it to specialist to solve this problem.
If it doesn't affect SRS system functionality...i'll leave it alone...for now(untill i wold have some extra time).
Pictures are comming.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 413 times
Been thanked: 1270 times
This has been debated here, hotly.
We don't have access to the SRS source code, so no one really knows if the light represents a disabled condition or not
On VW, it does not.
Link To Volvo Glossary
misha
Post by misha »
Here are the pics of S,v70 cluster into '97 850:
And here is Vol-FCR SRS scan result:
The problem is abscate...that the light is probably disabled on the circuit board by previous owner.
SRS light is not illuminating with other little lights when key is in pos.II and that is the only SRS code,because of the cluster.
It's not showing any kind of problems with SRS system,but i'm worried can a DTC for SRS warning light OC(open circuit) or SC (short circuit) to ground disable SRS system.
The cluster came from the Volvo junkyard.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The code can be written to shut off SRS on any fault but we just don’t know if that is the case or not.
Short of getting someone in Volvo to tell us, we won’t know.
misha
Post by misha »
I put back the original cluster until i figure out how to solve the issue with SRS code for warning light i'm getting with s,v70 cluster.
I'm not risking to drive the car with possible disabled SRS system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Re: Early & late 850 instrument cluster compatibility  Topic is solved
Post by misha »
SOLVED!!!
In order to have properly working SRS warning light and no SRS 127 code stored in SRS system,you just need to add a wire from ignition switch(x-supply,yellow violet wire)to connector "B" on pin B5.
B5 is spare in '96 & '97 850.
That's all.
850 broken odometer gears...permanent fix!!! :!: :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
I guess that this topic title should be re-named in s,v,c70 instrument cluster in '96 & '97 850.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
