Did you know? 🤔
Bosch Parts List for P80 Models (1998 S70 V70 2.4 liter)
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 20 times
Been thanked: 25 times
United States of America
Eddystone
Post by Eddystone » Mon Feb 18, 2019 12:36 pm
This is the result of a search done at the Bosch website for my 1998 Volvo V70 2.4 liter which I thought might be a useful reference. I suggest that you do your own specific model search at their website. Some of these parts seem to be common to all P80s, but some are specific. Notably, I did not search on the 2.3 liter engine in the T5.
This information presented here was downloaded from Bosch on February 18, 2019. Note that some parts reference specific chassis numbers, turbo vs non-turbo, et cetera. I've highlighted some part numbers but ran out of steam for editing brake pads and windshield wipers. I've also altered the listing order to put the electrical parts and sensors higher in the order.
https://www.boschautoparts.com
Contact Us: 888 715 3616 IN NORTH AMERICA
8AM - 5PM CST MON-FRI
Alternators and Starters
Brakes
Filters
Oxygen Sensors
Batteries
Spark Plugs
Air Management Sensors
Wiper Blades
Engine Position Sensors
Fuel Injectors
Ignition Parts
Remanufactured Alternators
Bosch Remanufactured Alternators have more new parts and are performance tested to ensure longer, more reliable operation with maximum performance.
DriveType: FWD, Aspiration: Naturally Aspirated,Turbocharged
Installation Restrictions: 100 A, Actual OE part
Part Number: AL0752X
Installation Restrictions: 80 A
Part Number: AL0753V
Remanufactured Starters
Bosch Professional Preferred Remanufactured Starter Motors are built for extreme heat, cold and high demand. Every engine starter component is 100% factory tested prior to and during remanufacturing to assure it meets or exceeds original equipment specifications.
Installation Restrictions: Actual OE part
Part Number: SR0483X
Oxygen Sensors
Premium Oxygen (O2) Sensors
Bosch invented the automotive oxygen sensor, which is also referred to as an O2 sensor or lambda sensor. Our Premium Oxygen Sensors are thimble and planar switching sensors that are designed to meet or exceed OE specifications.
DriveType: AWD,FWD, Aspiration: Turbocharged, Position: Downstream
Installation Restrictions: To Chassis # #342001, To Chassis # 342000, To Chassis # 342001
Part Number: 15063
Position: Upstream
Part Number: 15097
DriveType: AWD, Aspiration: Naturally Aspirated,Turbocharged, Position: Downstream
Installation Restrictions: From Chassis # 342001, From Chassis # #342000
Part Number: 15062
Universal Oxygen (O2) Sensors
Premium Universal Oxygen Sensors with OE SmartLink are quick and easy to install. Each sensor has two-feet length of sensor wire to allow maximum replacement of worn harnesses.
DriveType: AWD,FWD, Aspiration: Naturally Aspirated,Turbocharged, Position: Upstream,Downstream
Installation Restrictions: From Chassis # 342001, To Chassis # #342001, To Chassis # 342000, From Chassis # #342000, To Chassis # 342001
Part Number: 15738
Spark Plugs
Platinum Spark Plugs
Bosch Platinum Spark Plugs are engineered for up to 2X longer service life.*
Installation Restrictions: Do Not Gap, Gap is Preset, Original Equipment Is Platinum
Part Number: FR7DPP+
Copper with Nickel Spark Plugs
Bosch copper core spark plugs feature a heavy-duty nickel center electrode for longer lasting service life compared to standard copper plugs.
Installation Restrictions: Gap 0.028 in
Part Number: 7955
Installation Restrictions: Do Not Gap, Gap is Preset, Original equipment is nickel
Part Number: 7401
Mass Airflow Sensors
Bosch is an original equipment global leader in mass air flow technology. Bosch Mass Air Flow (MAF) sensors ensure low levels of harmful emissions with greater fuel efficiency and improved engine performance.
Part Number: 0280217107
Camshaft Position Sensors
Bosch Camshaft Position Sensors determine engine position based on the location of the camshaft: engine position is used for determining injection and ignition sequence.
Part Number: 0232101030
Knock Sensors
Bosch Knock Sensors are highly accurate and sensitive to detect engine knock, ensuring efficient performance and long life of your vehicle.
Part Number: 0261231121
Fuel Injectors
PFI (Port Fuel Injection)
Bosch Port Fuel Injectors (PFI) have a robust design and are capable of using Ethanol fuel (E100). All Bosch fuel injectors released to the aftermarket are OE fit, form and function, and are produced to OE specifications. The Bosch fuel injector has a return rate of 1 part per million (PPM), making Bosch the industry benchmark.
Installation Restrictions: Actual OE part, One per cylinder
Part Number: 62687
Part Number: 62682
Ignition Parts
Ignition Coils
All Bosch ignition coils are built to achieve or exceed OE specifications and are known industry-wide for their reliability and performance. Bosch ignition coils convert low voltage into high ignition system voltage, creating an electric spark sent to the spark plugs which ignites the fuel.
Part Number: 0221601012
Ignition Coils
Part Number: 0221604008
Brakes
QuietCast™ Premium Disc Brake Pads
Developed for the generalist who works on all makes and models all day long, this premium line raises aftermarket brake pad technology to a whole new level.
Submodel: AWD,X/C AWD, DriveType: AWD, Position: Rear
Part Number: BP391
Submodel: Base,GLT,T5, DriveType: FWD, Position: Rear
Part Number: BP31
Position: Front
Installation Restrictions: w/15" Wheels;
Part Number: BP618
Position: Front
Installation Restrictions: 16 or 17" wheel;
Part Number: BP783
Position: Front
Part Number: BC618
QuietCast™ Premium Disc Brake Rotors
Innovative, high quality materials provide consistent, safe and long lasting performance.
Position: Front
Installation Restrictions: 280mm rotor;
Part Number: 52011347
Part Number: 52011356
Part Number: 53011385
EuroLine Disc Brake Pads
This line provides the best performance for the most popular European vehicles on the road in North America, such as BMW, Mercedes Benz, Audi, VW, Volvo, Saab, etc.
Part Number: 0986466302
Blue Disc Brake Pads
Created for the generalist who wants to give their customers the best value.
Position: Front
Part Number: BE618
Part Number: BE31
Part Number: BE391
Position: Front
Part Number: BE783
Blue Brake Shoes
Engineered to match OE design and provide consistent, superior braking performance.
Position: Rear
Installation Restrictions: Bosch Parking Brake Shoes;
Part Number: BS827
Filters
Premium Oil Filters
Premium engine performance requires a premium oil filter. Bosch Premium Oil Filters protect your engine by keeping harmful particles and dirt out, preventing premature wear and engine failure. Premium oil filters not only fit the same way as original OE filters, they utilize an exclusive blend of natural and synthetic materials in the media for superior oil filtration and increased engine protection.
Part Number: 3321
Workshop Oil Filters
Bosch Workshop Oil Filters designed for the professional installer.
Part Number: 72138WS
Workshop Cabin Air Filters
Bosch Workshop Cabin Air Filters are specifically engineered for the professional installer dedicated to helping customers breathe cleaner air. Bosch Workshop Cabin Filters offer an 80%* efficiency rate at 3 microns or greater in capturing dirt, dust and other environmental contaminants from entering the heating and air vents of a vehicle.
Part Number: P3700WS
Workshop Air Filters
Bosch Workshop Air Filters are designed specifically for the Professional installer market offering 90% vehicle coverage to ensure installers will always have the right air filter.
Part Number: 5280WS
Batteries
S6 High Performance AGM™ Battery
Bosch S6 High Performance AGM™ Batteries provide excellent charge acceptance & peak power for vehicles with start/stop systems, regenerative braking & the highest electronic demand. The S6 features AGM™ technology & satisfies the highest starting & power supply standards even in extreme hot & cold climates.
Installation Restrictions: Battery gasses need to be vented to outside.;Installation may take over 30 mins., Battery located in trunk. Spare tire may have to be removed, OE CCA: 600, OE Group: 48
Part Number: S6585B
Installation Restrictions: Battery gasses need to be vented to outside.;Installation may take over 30 mins., Battery located in trunk. Spare tire may have to be removed, OE CCA: 520, OE CCA: 600, OE Group: 47, OE Group: 48
Part Number: S6-47
S5 Battery
The Bosch S5 Car Battery is well suited for premium car segments including upper-class domestic, imported segments & vehicles with a high number of electrical consumers. The S5 Battery delivers dependable power in extreme temperatures & other high demand situations.
Installation Restrictions: Battery gasses need to be vented to outside.;Installation may take over 30 mins., Battery located in trunk. Spare tire may have to be removed, Hold-down on long & short side of battery, OE CCA: 600, OE Exact Fit, OE Group: 47, OE Group: 48
Part Number: S5531B
S5 Battery
Part Number: S5532B
S4 Battery
The S4 is an all-around battery focused on mid-size car segment with average number of electrical consumers.
Part Number: S4-48
S3 Battery
The S3 Battery is an economical solution for older cars with less electrical equipment.
Installation Restrictions: Battery gasses need to be vented to outside.;Installation may take over 30 mins., Battery located in trunk. Spare tire may have to be removed, OE CCA: 600, OE Exact Fit, OE Group: 48
Part Number: S3-48
Wiper Blades
ICON™ Wiper Blades
The premier solution for the winter season is the Bosch ICON beam wiper blade. By design, beam blades are not affected by snow and ice buildup. The bracketless design and tension springs help keep the blade flexible and provide superior wiping performance in all climate conditions.
Position: Front
Part Number: 21A
Evolution Wiper Blades
The patented design of Bosch Evolution beam blades feature dual precision-tensioned steel springs that distributes uniform pressure along the entire length of the blade for exceptional for winter weather visibility.
Position: Front
Part Number: 4821
Clear Advantage Wiper Blades
Patented beam design for all-weather performance
Position: Front
Part Number: 21CA
Insight Wiper Blades
This innovative hybrid blade has a streamlined design that utilizes patented single beam technology to help provide a replacement for your vehicles original equipment, hybrid windshield wiper blade.
Position: Front
Part Number: 4921
Excel+ Wiper Blades
Advanced rubber technology in a conventional windshield wiper blade design for quiet operation, a cleaner wipe and longer life.
Position: Rear
Part Number: 41917
Excel+ Wiper Blades
Position: Front
Part Number: 41921
MicroEdge Wiper Blades
Robust construction with a specially blended natural rubber wiping edge for reliable windshield wiper performance.
Position: Rear
Part Number: 40717A
Position: Front
Part Number: 40721
DirectConnect™ Wiper Blades
Designed for dependable windshield wiping performance with quick and easy installation.
Position: Front
Part Number: 40521
Position: Rear
Part Number: 40517
OE Specialty AeroTwin Set
Bosch continues its innovation and expands its wiper blade portfolio by providing wiper blades with unique, special adapters that are hard to find in the market for your vehicle. Bosch AeroTwin Set features a complete replacement set for your vehicle.
Position: Front
Installation Restrictions: Set
Part Number: 3397118401
ENVISION™ Windshield Wipers
Driving in the rain can be stressful, especially at night. The new Bosch ENVISION™ windshield wiper blade sharpens night visibility and offers extreme weather safety.
Position: Front
Part Number: EN21
Spectrum DirectFit Beam Wiper Blades
Bosch Spectrum DirectFit™ Beam matches the same blade technology and connection fitment to deliver factory performance. The patented beam design with aerodynamic spoiler provides long-lasting wiping performance in all weather.
Position: Front
Installation Restrictions: Upgrade to Beam for longer lasting performance
Part Number: B2101
FOCUS Windshield Wipers
Driving in the rain can be stressful, especially at night. The Bosch FOCUS™ windshield wiper provides optimal night clarity and enhances safer driving.
Position: Front
Part Number: FS21
Snow Driver Wiper Blades
The new Bosch Snow Driver™ windshield wipers are tested to perform at -20°F providing advanced winter dependability. Cut through the harsh winter elements with reliable operation during all conditions.
Position: Front
Part Number: 21SD
Spectrum DirectFit Conventional Wiper Blades
Bosch Spectrum DirectFit™ Conventional matches the same blade technology and connection fitment to deliver factory performance. The precision cut rubber wiping edge delivers a quiet, consistent performance.
Position: Rear
Installation Restrictions: Factory Replacement
Part Number: C1706
Position: Front
Part Number: C2107
PureVision Wiper Blades
Bosch PureVision™ wiper blade program, a beam technology that delivers high wiping quality for all-weather performance.
Position: Front
Part Number: 21PUV
Winter Wiper Blades
When cold weather gets extreme, Bosch Winter beam wiper blades can stand up to even the harshest conditions.
Position: Front
Part Number: 21BW
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
clarkerussell
Year and Model: 1998 S70 GLT
Has thanked: 13 times
clarkerussell
Re: Bosch Parts List for P80 Models (1998 S70 V70 2.4 liter)
Post by clarkerussell » Mon Feb 18, 2019 10:46 pm
The Bosch parts guide said my 1998 S70 GLT should use alternator AL0805X, but it's not at all the same unit.
The 2.4L engine reference says to use AL0805X
The 2.3L says to use AL0752X
My GLT is a 2.4L Turbo, and it's definitely NOT the AL0805X as the mounting points are completely different. The AL0752X looks correct.
