Did you know? 🤔
Difficulty starting with ECM-201A and ECM-2000 codes
ddmd
Year and Model: 1999 XC70
Has thanked: 0
Been thanked: 0
United States of America
ddmd
Post by ddmd » Mon Feb 18, 2019 5:33 pm
Hi Everyone. I can use some help. I have a 2000 V70 XC with 202,000 miles.
I experienced a sudden difficulty starting (long normal sounding cranking, starts after several tries)
along with a CEL. Once running, it seems to run normally. Prior to this, starting was easy and reliable.
A VIDA diagnostic check revealed the following codes:
ECM-201A Thermostat - Faulty signal
ECM-2000 Engine coolant temperature (ECT) sensor - signal too low
Under related CSC in VIDA for the ECT sensor, it describes difficulty starting "Engine hard to start/cranks slowly,
Unsure when/at all times"
Does anyone know what the relation is between the ECT sensor and starting? Also, in my case, the cranking
is normal (rapid), not slow.
Has thanked: 267 times
Been thanked: 846 times
Trinidad & Tobago
Re: Difficulty starting with ECM-201A and ECM-2000 codes
Post by abscate » Mon Feb 18, 2019 5:48 pm
The sensor and wiring can go bad, which then screws up the injection amount sent by the. Engine control module, or ECM. This gives the hard start or even no start
Your 1999 uses a 3 year only ECT part 9125463
If you search that part number, you should find a thread where the resistance measurements are listed for testing, if you know how to use a volt ohm meter
Link To Volvo Glossary
ddmd
Has thanked: 0
Been thanked: 0
ddmd
Post by ddmd » Mon Feb 18, 2019 6:14 pm
Thanks for the quick reply. I'm glad that there's an explanation that makes sense. I found the resistance chart
and will check it.
ddmd
Has thanked: 0
Been thanked: 0
ddmd
Post by ddmd » Mon Feb 18, 2019 8:21 pm
It looks like it's the ECT sensor. It measures >6K ohms at both 0 deg C and 20 deg C.
Thanks for the help! I appreciate it.
Trinidad & Tobago
Post by abscate » Tue Feb 19, 2019 2:03 am
You should go OEM on that part, or find one from a runner in a junkyard
Aftermarket reportedly often don't work well.
ddmd
Has thanked: 0
Been thanked: 0
ddmd
Post by ddmd » Tue Feb 19, 2019 10:07 pm
Thanks. Yes I did order the OEM parts. Hopefully they'll arrive in a day or so.
