IPD sale Volvo Parts
Did you know? 🤔
1999 S70 "AWD" Rescue Thread
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 53 times
Been thanked: 53 times
Canada
WhatAmIDoing
Re: 1999 S70 "AWD" Rescue Thread
Post by WhatAmIDoing » Wed May 08, 2019 7:42 pm
Took her on the highway after getting the Ariane wheels on. Ride was better than expected with wasted struts/shocks. Crossed my fingers for cruise control... and of course it doesn't work.
Unfortunately this project ground to a halt today. As I reached down to pull the hood release, my hand was met by a limp handle and cable. Now I'm going to have to try and get the hood open tomorrow. Not looking forward to it.
'98 S70 T5M - 270,000+mi - forever a project
'99 S70 "AWD" - 218,000+mi - project
Knows enough to be dangerous :wink:
Has thanked: 185 times
Been thanked: 570 times
Trinidad & Tobago
Post by abscate » Wed May 08, 2019 8:57 pm
On a 1999, cruise is integrated into the ETM. If you recently cleared codes or disconnected the battery , you will need to drive it a bit before cruise is re-enabled
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
bmdubya1198
Year and Model: '98 V70 GLT
Has thanked: 26 times
Been thanked: 68 times
United States of America
bmdubya1198
Post by bmdubya1198 » Wed May 08, 2019 9:31 pm
Best way to do that is wedge a thin screwdriver or something between the hood and fender to release the turn signal, then get creative with a coat hanger, pick, pliers, or something to release that hood latch. Been there, done that! Multiple times!
1998 V70 GLT Black/Beige 191k
2000 V70R Venetian Red/Charcoal M56 Swapped 188k
2001 S60 2.4T Black/Black 230k
2007 XC90 V8 AWD Sport Titanium Grey/Black 151k
1998 S90- Silver/Gray 207k
1995 850 collection of parts... crushed... still have parts, PM if interested!
1988 744 Turbo M46 Beige Metallic/Beige 188k- Still kicking myself for getting rid of this one
WhatAmIDoing
Canada
WhatAmIDoing
Post by WhatAmIDoing » Wed May 08, 2019 9:48 pm
Battery was dead when I bought it, and today was probably the first time it really completed a drive cycle. Will drive more and see if it starts working.
Yeah I'm not really looking forward to it. Fortunately there's a fair bit of gap around the hood. And one turn signal is busted, so I don't feel too bad about ripping it out. What's the angle I need to go for on this one?
callahanoffroad
Year and Model: 1995 850
Has thanked: 14 times
Been thanked: 14 times
callahanoffroad
Post by callahanoffroad » Thu May 09, 2019 7:48 am
On the turbo PSI. IIRC the TCM on Volvo's regulates the wastegate. The TCM is controlled by the ECU and if it's a LPT ECU that hasn't been tuned it'll blow the standard 6psi. This can be adjusted by tuning or a Manual Boost Controller (aka a bleed valve). So it could be an R manifold and turbo but w/o the tuning or ECU from a high pressure turbo it will not act like an R. Just my $.02
All 850's use a TD04 turbo just with different turbines (and maybe flanges?) IIRC. Not a TD04 expert as in tuning circles they were always viewed as a stock or unbuilt engine turbo. I think the optimum max boost is somewhere between 16 and 18 psi. Someone jump in here and correct me. 😁
Excited to see this build!
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. Herman. https://www.matthewsvolvosite.com/forum ... =1&t=84393
manovlov
Year and Model: 850 WAGON 95 2.5-20V
Has thanked: 37 times
Been thanked: 8 times
France
manovlov
Post by manovlov » Thu May 09, 2019 8:05 am
WhatAmIDoing wrote:
Sat May 04, 2019 9:00 am
So I was finally able to pick up the '99 S70 AWD I saved from the crusher. $400 for the car with 218k miles (and 4 good Blizak snow tires) + $200 for brand new Falken sport tires on decent Ariane rims. Not a bad deal. She started right up and drove a few miles perfect.
What needs fixed ASAP: Needs new shocks / struts on all 4 corners (bouncy, bouncy). Heater core is 10/10 blown; heat wreaks of coolant and windshield has an oil film on it. Lastly, the ECC is having some issues. Driver's side vents only blow full hot (with summer coming that's a big TO DO), and the directional motor is a little lazy. Passenger side ECC everything works as expected.
The Good: interior isn't destroyed, all fluids look clean, paint is okay, found Volvo touch up paint in the trunk with some new front turn signals, and PCV and timing was done by Volvo at 205k miles.
Let the project begin...
... One day, my prince will come !
Well play callahanoffroad !
Manov
Vroum !
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Thu May 09, 2019 8:16 am
The TCV controls the wastegate, the TCM is the transmission control module on automatic cars. But yeah, the ECU controls the TCV to regulate boost. A manual boost controller can be used on 1998 and older models, but Motronic 7 does not cooperate with MBCs.
The turbines were all the same, but the compressor side is what changed. These P80s all used TD04HL turbos, with a 13g/13t, 15g/16t, 18t, or 19t compressor housing depending on the engine (LPT, HPT T5/R) and year. The exhaust flange to the downpipe is the only thing that changed on the exhaust side, being a conical flange on 1994-1995 (I think), straight on 1996-1998, and angled from 1999+.
Boost limits depend on the compressor. A 13g runs out of steam past probably 13 PSI, while a 19t could be pushed to 22-23
PSI efficiently.
For the turn signal, you'll just need to push down that tab and pull straight out. Then for the hood latch, use a flashlight and peek into that hole in the fender behind the turn signal, and see if you can see the tab on the hood latch where the cable from the cabin connects. Get something on there and pull.
I have an emergency cable on my '98 that I made with some garden wire. That way I can just pull the turn signal, grab on to the cable and pop the hood. Definitely a good idea to make a backup!
callahanoffroad
callahanoffroad
Post by callahanoffroad » Thu May 09, 2019 9:55 am
TCV! That's it. As back in the day I worked mostly with Honda's, Subies, and other Japanese cars they didn't have that. It was all vacuum actuated wastegates. Btw in my head it was "Turbo Control Module" hahaha aka EBC Electronic Boost Controller. :-)
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 1 time
Been thanked: 30 times
tardcart
Post by tardcart » Thu May 09, 2019 10:15 am
drivers side only on the hood latch. cant on pass side
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Thu May 09, 2019 12:04 pm
Yeah, if the cable between the latches is in tact then you will be able to open both from that driver side latch.
