IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? πŸ€”
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
The craziest problem with 96 Volvo 850 T5 Topic is solved
misha
Year and Model: '97 850 2.5 20v
Has thanked: 49 times
Been thanked: 112 times
Serbia
misha
Re: The craziest problem with 96 Volvo 850 T5 ( bad KAE fuel injection relay)
Post by misha » Fri Nov 01, 2019 3:21 am
You will need a special Volvo scanner....at least Vol-Fcr.
It can clear service light and you will have access to every module in the car except ECU since it produce flash codes being a M4.3 on a T5.
I have old version for old desktop or laptop with serial DB9 to OBDII cable bought 10+ years ago.
There are newer versions which can display live data too with usb to obdII cable.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
850oldschool
Year and Model: 1995 850 NA
Has thanked: 0
Been thanked: 3 times
United States of America
850oldschool
Post by 850oldschool » Fri Nov 01, 2019 10:48 pm
I recently picked up a used iCarsoft i906 for $70 on ebay. It claims it will do engine, transmission, airbags, and ABS. My car is a manual and I've only used the engine diagnostics so far.
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 13 times
Been thanked: 14 times
esl_97_850_T5
Post by esl_97_850_T5 » Sun Nov 03, 2019 9:47 am
Similarly, xiaotec "850 OBD-II" Android app, in conjunction with an appropriate ELM327 tool, can read/clear the special Volvo codes.
2009 Yamaha Vino 125cc (daily driver)
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
redbeak1
Year and Model: 850t5 1996
Has thanked: 4 times
redbeak1
Post by redbeak1 » Sat Nov 23, 2019 9:34 pm
After a whole year of intermittent stalling and crank but no-starts, the problem was finally found. In July of last year I changed the fuel injection relay (the grey KAE that goes on top of the radiator) thinking that after 23 years it may be causing a no start issue at times. Well, after thousands of miles and over a year of following all the great advice on this forum the car finally died where I couldn't start it all. The P0120 code still came up,but I could not clear it as before. Luckily my Volvo had the decency to die in my garage. So after a week at Kundert Volvo they found out that the FI relay was cutting out intermittently. I put in this brand new KAE from FCP but it was defective from the factory. Not blaming FCP. They are great!!! Nobody really thought to check this since I wrote on the relay "New 7-18"
My question is: Why does it come up as a TPS sensor CEL? Thanks to all very much for all your help. Nice to have my confidence back in my Old great Volvo!!!
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 272 times
Been thanked: 849 times
Trinidad & Tobago
Re: The craziest problem with 96 Volvo 850 T5  Topic is solved
Post by abscate » Sun Nov 24, 2019 3:55 am
Classic! Well done! The only thing worse than parts swapping is bad parts Swapping!
The fuel injection relay probably supplies voltage to the fuel injectors and ignition circuits, the low voltage to the TPS was getting generated by that
The only way you could have caught this is
On stalling, ether test would confirm a no fuel condition
Fuel pressure test would confirm fuel delivery is ok
That would point you to injector circuit , an oscilloscope trace in the fuel injectors would shine the light.
Hmmm, where do you find an oscilloscope on lane 7, upper deck of the GW?
πŸ€’πŸ€’πŸ€’
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
redbeak1
redbeak1
Post by redbeak1 » Sat Dec 14, 2019 9:39 pm
abscate wrote: ↑
πŸ€’πŸ€’πŸ€’
This sure was a tricky one. So far so good a month later!!! :D After the stall I did test the relay and it was working fine. Not with an oscilloscope. Would an oscilloscope pinpoint the issue...if after the stall the fuel injection relay reverts back to normal function again?
I had a similar issue working on my 1977 VW Bus with a crank but no start issue. I don't like swapping parts to find a problem, so I tested everything and it showed that the airflow meter was faulty. I sent it to Fuel Injection Corp in California. It came back as repaired and working. Same symptoms again!! Drove me nuts. I went through the entire system again. Wiring, connections etc. Back to airflow meter. I returned it to FIC and they saw that the repair didn't hold. So the big lesson here is that never assume anything. Maybe my Volvo FI relay was returned as defective by a previous customer and was just sent out again.
The good thing about stalling out on the GW is that everyone is only going 2 mph. The horrible experience was being on the NJ Turnpike pulling a motorcycle on a trailer in the fast lane and just dying with no warning. God was looking over us a few times!!
Well anyway, Thank you again for everyone's input. It was a great learning experience.
Trinidad & Tobago
Post by abscate » Sun Dec 15, 2019 8:04 am
A scope won’t be too useful on an intermittent relay. I wonder what the failure mechanisms are?
Coil overheating and opening circuit
Dirty points or chattering , voltage drop over the contact points ?
Might be good to measure parameters on a known to be good relay
