Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
Wastegate flapper
- Year and Model: 97 855R
- Has thanked: 0
Wastegate flapper
Guys I am rebuilding the head on my 850r and have the turbo off and decided to do it while off. The wastegate flapper appears to be able to move up and down a lot. If not I. The right position it allows a gap at the top or bottom of the port. Is this normal.
- greg850r
- Year and Model: a long list
- Been thanked: 9 times
Re: Wastegate flapper
I don't think it's normal but I can pull one off the shelf tomorrow and check. Meantime, a pic would be helpful if you have the parts on the bench.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
- Year and Model: '98 V70 GLT
- Has thanked: 31 times
- Been thanked: 107 times
It's normal for the flapper itself to move around a bit when it's open, but when the wastegate is closed (held shut by the actuator) it should seal tight.
2000 V70R Venetian Red/Charcoal M56 Swapped 191k
2000 S70 GLT Mystic Silver/Taupe 2??k
2003 S60 2.4T Silver/Black 108k
2007 XC90 V8 AWD Sport Titanium Grey/Black 160k
1993 944 Base Beige/Beige 221k
1992 Miata Mariner Blue/Black 146k
1998 V70 GLT Black/Beige 193k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k- Never should have sold it
Need used parts? PM me!
- Has thanked: 0
I will take some pics. I jb welded it. The door fits in a bushing and the bushing moves up and down allowing it to leave a gap. I got the bushing to stop moving so now just the door moves. No more up and down. Just open and close.
Uhhh... sounds to me like you're setting yourself up for boost issues, whether that's over- or under-boosting depends on how you JB welded it.
Pics will be necessary here.
- These users thanked the author bmdubya1198 for the post:
Go into "full editor & previrw" or click "post reply" at the top of the thread, then just below the text box, you can select "attachments" and upload it from there.
Otherwise, you can post from an image hosting site like Imgur using the BB code link option.
- Has thanked: 0
The part that is jb welded is the bushing that the flapper shaft sits in. It is the part that is moving up and down.
Ah, I see. I don't think I've seen that repaired that way before... best bet is to get a new turbine housing.
- Year and Model: 2000 V70XC
- Has thanked: 22 times
- Been thanked: 26 times
That's odd. I'd be concerned about that JB Weld inside the housing coming loose and breaking apart after so many heat cycles. Debris like that would not be great to hit spinning turbines and go down the intake into engine.
2000 V70XC - 288,000 miles
98 V70 T5 Wastegate Rod Adjustment Results
by sleddriver » Thu Mar 10, 2016 3:12 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 9 Replies
- 3648 Views
Last post by sleddriver
Wed Jun 01, 2016 8:26 pm
Wastegate adjustment time
by JDS60R » Fri Mar 11, 2016 1:10 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 610 Views
Last post by JDS60R
Fri Mar 11, 2016 1:48 pm
1996 855 T5 - Musings on Wastegate Adjustment
by Sommerfeldt » Wed May 11, 2016 10:29 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 27 Replies
- 4658 Views
Last post by wizechatmgr
Tue Apr 10, 2018 7:40 am
C70 B5244T 2000 wastegate pressure
by jantt » Mon Dec 26, 2016 12:56 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 3 Replies
- 337 Views
Last post by jantt
Wed Dec 28, 2016 4:10 am
