IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Alternator installation question
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 39 times
United States of America
amblerman
Post by amblerman » Tue Sep 10, 2019 7:13 am
Hi folks,
I just got a new alternator for my 99 s70.
It came with a tag that states.
1: Batter must be fully charged prior to installation of alternator.
2: Battery cables must be removed from batter prior to connecting opposite side of cables to alternator Failure to do so may damage diodes.
I already have the battery fully disconnected but that last statement got me thinking. Why would not fully disconnecting battery damage diodes? Also, if you don't have battery fully disconnected, does this also imply there is a correct order in which the battery cables need to be reconnected so you don't get into the same situation and damage diodes?
I was planning on reconnecting all positive connections first and then the negative last.
Can anyone explain what combination of having the cables attached or attaching in incorrect order can damage diodes?
Thanks
-A
Herb Goltz
Year and Model: V70 2000
Has thanked: 1 time
Been thanked: 2 times
Canada
Herb Goltz
Re: Alternator installation question
Post by Herb Goltz » Tue Sep 10, 2019 7:29 am
I have always connected the negative last, and have never had a problem. I think the real concern is swapping the pos and neg, which could damage the diodes, which are "one way streets" for the current.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 363 times
Been thanked: 1114 times
Trinidad & Tobago
Post by abscate » Tue Sep 10, 2019 10:09 am
I think its just a liability clause where they want you to connect the battery last, so that if you screw that up, you made the mistake.
It is correct practice to connect positive first and negative last, but there is no reason to disonnect the positive if the negative is off and isolated so it can't touch the battery post.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Tue Sep 10, 2019 12:15 pm
The reason I disconnected the positive side of the batter is to eliminate the possibility of my wrench hitting a ground while tightening the positive cable (which would be live if the positive terminal on battery were connected) on the alternator B+ connection.
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Tue Sep 10, 2019 12:18 pm
Thanks.
I figured swapping +/- would be a big issue but I was wracking my brain trying to figure out how connecting it normally (ie proper +/-) would be an issue. I couldn't come up with a scenario as it's impossible to connect the alternator wrong on these cars.
ie: ground for alternator is bolts to engine, 1 +B wire and the tiny wire that connects with a plug. Impossible to wire it up incorrectly.
-A
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 24 times
Been thanked: 54 times
BEJinFbk
Post by BEJinFbk » Tue Sep 10, 2019 12:57 pm
If the negative terminal of the
battery is disconnected, it doesn’t
matter if the wrench on ANY positive
connection hits anything anywhere.
No negative still means no power flow.
That’s why you always make negative
first to disconnect, last to connect. 👍
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Tue Sep 10, 2019 1:04 pm
Oh my gosh. I don't know what I was thinking. Of course that's true. What I was talking about would be true if and only if the negative was till connected .
So.. I need to amend my statement.. I don't know why I disconnected the + and - other than it's easy now that I have quick disconnect style terminal ends.
:D
Man.. I can't believe I made such a bone headed mistake....
-A
