Did you know? 🤔
What dimensions is the brake rotor guide pin?
diplomaticm3
Year and Model: 2004 xc70
Has thanked: 1 time
Been thanked: 0
United States of America
diplomaticm3
Post by diplomaticm3 » Thu Oct 17, 2019 6:56 pm
Anyone else use a substitute from a hardware store? I find it hard to shell out $80 for 4 x small pins.
Thanks in advance.
jimmy57
Has thanked: 2 times
Been thanked: 204 times
jimmy57
Re: What dimensions is the brake rotor guide pin?
Post by jimmy57 » Thu Oct 17, 2019 8:30 pm
6mm-1.0 bolt 15 mm long
They are optional. the pin on head was to assure the wheel went on in one place if it were dynamically balanced on the car. That has not been done by tire stores in 25 years or longer. The bolt was used to hold rotors onto hubs for shipping prior to new vehicle manufacture. They are a mild convenience when you remove brake pads for pad change other rotor and hub repairs. If you leave them out nothing will happen. You may have worked on an American made car and found a round odd washer with rolled up "fingers" on the inside diameter. Those were for the same purpose, they hold drums on axles for shipping prior to vehicle build. Once removed they are not replaced as they have no purpose.
diplomaticm3
Has thanked: 1 time
Been thanked: 0
diplomaticm3
Post by diplomaticm3 » Fri Oct 18, 2019 12:23 am
Really? Huh...that’s good to know.
I was under the impression that they “center” the rotor and prevent warping. But now that makes less sense to me as I’ve had other cars with this item removed & nothing happened.
Has thanked: 74 times
Been thanked: 237 times
Post by erikv11 » Fri Oct 18, 2019 9:48 am
For me they are more of a mild inconvenience, making sure the wheel lines up.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
jimmy57
jimmy57
Post by jimmy57 » Fri Oct 18, 2019 2:12 pm
On P3 they went with countersunk screws for this so you lose that assistance.
Has thanked: 248 times
Been thanked: 806 times
Trinidad & Tobago
Post by abscate » Sat Oct 19, 2019 7:42 am
On my steelies, the pins are great as they help hold the wheel on as I replace.
For my alloys , they go into a single blind hole so they are a bit of a hassle
I guess they are like bacteria, some good , some bad
Link To Volvo Glossary
