IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Advice sought on how to flatten a bowed plastic cowl
jreed
Has thanked: 97 times
Been thanked: 52 times
Post by jreed »
The plastic cowl cover on our '97 850 started to bow a few years ago. I added a little hold down made out of a cable tie, which worked pretty well for a while. But now the plastic is bowing again. Has anybody else observed this problem? What have you done to fix it? Thanks.
Has thanked: 395 times
Been thanked: 1234 times
Re: Advice sought on how to flatten a bowed plastic cowl
What’s under there😳?
Can I send you a spare somehow?
Link To Volvo Glossary
RickHaleParker
Has thanked: 3 times
Been thanked: 621 times
Post by RickHaleParker »
I would use a Heat gun to soften it up then reform it. A hair blow dryer should do the trick if you do not have a heat gun.
Wait what am I saying? .... a hair blow dryer is a heat gun.
2004 S60R, B8444S TF80 AWD.
Is that just bowing under the tension of the zip tie? It looks too tight.
It should take another screw holding it down through the boss up top
If the plastic underneath is broken, build up with JB Weld, still a pilot hole, and replace screw
Has thanked: 22 times
Been thanked: 275 times
The other option is to find a better replacement at a junkyard. The plastic is close to 25 years old so likely to suffer from age issues like myself! I think a combo of what Rick and Steve have suggested can work using self threading bolts/screws with large washers, drilling a couple of holes and first heating the plastic before putting the screws in.
If your car is otherwise still in very good condition and you want to keep it that way, then a better used example is the way to go. You may have to find one from a more northerly state where year round temperatures are lower so the plastic may still be more supple.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Argh , you need the -1997 draining channel
9151056 NLA new
Stick a request in the junkyard request sticky in CLASSIFIEDS
1998- on won’t work, different part number,
9127584
that one is still available
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 189 times
Post by bmdubya1198 »
The heat gun idea is a good start, see if you can get it nice and warm and try to flatten it out. Then, use the correct screw in that spot to bolt it down. Looks like it's broken, so some JB Weld and a washer might be a good way to fix that.
Otherwise if all else fails, that's a good thing to grab at the junkyard. I might even have one somewhere.
'00 V70R Venetian Red/Charcoal M56 Swapped 200k
'03 S60 2.4T Silver/Black 118k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
1998 V70 GLT Black/Beige 205k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
RickHaleParker
scot850 wrote: Sun Feb 23, 2020 8:01 am I think a combo of what Rick and Steve have suggested can work using self threading bolts/screws with large washers, drilling a couple of holes and first heating the plastic before putting the screws in.
Soften it up just a little then clamp a straight edge along the straight edge of the plastic, let it cool in a new form. Might need to heat the rest when the edge is clamped down for tension relief .
Excellent addition, wish I had thought of that, and the further suggestion of a little more heat once clamped to reduce the natural plastic will to bend is also excellent.
2006 XC70
