Did you know? 🤔
Replacing knuckle - abs and wheel hub questions
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 65 times
Been thanked: 14 times
United States of America
smacknab
Post by smacknab » Tue Mar 03, 2020 12:08 pm
A while ago I drilled out a caliper bolt to replace my calipers, but I accidentally drilled into my knuckle in the bolt channel. I'll soon be replacing my struts so I figured it was a good time to swap the knuckle with a used part I got from a salvage. The wheel bearing on the used knuckle is a little noisey but pretty smooth, so I'm not sure if I should swap the old bearing onto the new knuckle, or if at 210k miles I should swap both the front wheel hubs. Does anyone have any insight on the average lifetime of a wheel hub, and if the FAG hubs from FCP are fine, or if it's better to go with Volvo here?
The other question I had was about the abs sensor, as the knuckle also came with the wire/sensor. Is it better/easy to keep my current abs wire on, or should I keep the wire that's attached to the knuckle. I believe this came off a 2000/01 C70.
99 s70 NA m56 - >217k miles
Has thanked: 359 times
Been thanked: 1101 times
Trinidad & Tobago
Re: Replacing knuckle - abs and wheel hub questions
Post by abscate » Tue Mar 03, 2020 3:03 pm
Do you eat lots of 🥔?
FAG are fine. I’ve had three go from 110-180k miles
Link To Volvo Glossary
Has thanked: 18 times
Been thanked: 250 times
Canada
Post by scot850 » Tue Mar 03, 2020 3:13 pm
As for the ABS wire, it comes down to if you can remove it from the hub. If the hubs become really crusty in your area with rust, it might make sense to swap it all over including the wire.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 35 times
callahanoffroad
Post by callahanoffroad » Tue Mar 03, 2020 6:01 pm
Personally I would just go ahead and replace the hubs and bearings while they're off. I had to do mine at 200k and 220k respectively. Make sure you have the correct Volvo bolts for the hubs. Hex head bolt will rub on the axles ask me how I know hahahahaha
smacknab
smacknab
Post by smacknab » Tue Mar 03, 2020 7:43 pm
Thanks for all the tips. I jacked the car up to test the play in the wheel at 3+9 & 12+6 and found no play in the 12+6 direction, so i think they may be fine.. still an item that I will have on my list to replace.
What's bothering me more right now is that I had some decent play at 3+9 on both sides, maybe 1/2 inch(?) with a solid feeling clunk at the 'end' of each direction of play. I just replaced the inner and out tie rods recently.. does this mean a bad steering rack? Diagnostics I'm reading on steering racks only use driving indicators like vagueness, dead spots, sticky steering etc. its a little harder to steer than other cars in a parking lot, but not too bad.
Trinidad & Tobago
Post by abscate » Wed Mar 04, 2020 2:36 am
That does sound like rack, but control arms and ball joints last 100k In urban areas
smacknab
smacknab
Post by smacknab » Wed Mar 04, 2020 5:38 am
If it's the steering rack I'm dumping it's body by the dock in South Boston
Trinidad & Tobago
Post by abscate » Wed Mar 04, 2020 5:42 am
It is a bit of a drag but there are much worse things.
Marblehead is the preferred drop zone, after removing the wheels and leaving it on cement blocks
smacknab
smacknab
Post by smacknab » Wed Mar 04, 2020 12:03 pm
I'm trying to have that Buddhist 'the cup is already broken' mentality
Trinidad & Tobago
Post by abscate » Wed Mar 04, 2020 1:02 pm
Its more like a Zen - the cup half full of code P0455
