When I have cleaned out nasty fuel lines with sticky debris, I had success using a thin steel braided wire cable with the end slightly unraveled. The cable is stiff enough to push in the tube and can be twisted to stir and thread into the clogged material. This could work for a drain line as well.
Front Cowl Drain Lines
- Has thanked: 123 times
- Been thanked: 174 times
Re: Front Cowl Drain Lines
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
- Has thanked: 22 times
- Been thanked: 301 times
Remember now doing this on my parents 96 850 wagon. It is a swine to do due to that stupid idea of passing the zip tie through the pipe. Who ever thought that was a good idea? It is up there with dash board lights that light up at night even if your exterior lights are on, or the garage door openers in the car that stay live when the ignition is off?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
2006 XC70
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 12 times
For cleaning sunroof drain tubes I use a length of yard trimmer string. The thickest diameter is best. You can use it as a drain snake. It might help for this task as well. I also have found that reaching down and squeezing the drain tube helps break up the leaves and other stuff into smaller pieces so that they fall out the bottom.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- Been thanked: 10 times
I've use a coat hanger and compressed air to clean these. I have to clean then anually it seems.
- 192 Views
Last post by oragex
- 174 Views
- 430 Views
Last post by moonweasel
