Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
What is this hole for? - '98 C70 T5 Topic is solved
- mashinalens
- Year and Model: C70 T5 1998, Coupe
Hello All,
Recently I bought C70 T5 1998 (320k km) and went to a mechanic to change the fluids and the spark plugs. When he removed the engine cover I saw the hole which was sealed with some black material (a little bit soft when engine is hot). As I saw on photos of other T5 engines this hole should be free. Does anyone know what this closed hole can cause and why someone did this?
By the way, PCV system is clogged here (glove test was failed) and I plan to change it. I want to know, do I need to remove upper half of cylinder head to clean this black staff?
- RickHaleParker
- Has thanked: 3 times
- Been thanked: 647 times
Re: What is this hole for? - '98 C70 T5
Optional location for a PCV breather hose. Like the optional location for the oil filler.
If it is not leaking leave it alone. If you want it to look better cut it off flat.
As for why somebody would do that. We have seen this one time before and nobody has a clue.
2004 S60R, B8444S TF80 AWD.
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1339 times
I think tourist imports came with the henway option that mounted there
Link To Volvo Glossary
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 33 times
- Been thanked: 28 times
About three pounds.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
1993 945 Turbo/Auto
- mashinalens
But this black thing is making me crazy. I think previous owner thought that oil was dripping from it and seal it.
- mashinalens
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 69 times
- Been thanked: 43 times
Re: What is this hole for? - '98 C70 T5 Topic is solved
Rick hit the nail on the head, here's another thread for cross-reference:
viewtopic.php?t=74111
Doesn't matter if plugged or open to be honest.
- Year and Model: 240DL;850;S70
- Been thanked: 26 times
On my '94 it is for a tube belonging to the air pump system.
viewtopic.php?f=1&t=78097
- 284 Views
Last post by Ozark Lee
- 655 Views
Last post by Ou2mame
- 607 Views
Last post by crisnumbertwo
- 15 Replies
- 2329 Views
Last post by RussB
- 705 Views
Last post by frontrow
