This problem happened in around late April when we had the stay home advisory. When car is "cold" idle is fine, in park or waiting for traffic light. Once the car is driven for a while - "hot", idle speed goes up above 1300 rpm in Park position and a bit over 1000 rpm while waiting for traffic light.
Initially, I cleaned the IAC and the valve inside was moving freely when I shake the IAC. I also cleaned the throttle body too, not too much black deposit around the front and back side of the throttle body valve. Test drove the car after cleaning, same issue.
Then I got a new IAC from Volvo dealer and installed it. Still the same idle issue when car is "hot".
My car is 1995 NA wagon, what could be the problem here to cause the high idle in Park or waiting for traffic light ?
Thanks,
Ching-Ho Cheng
High Idle when car has been running for a while Topic is solved
- RickHaleParker
- Has thanked: 3 times
- Been thanked: 680 times
Check for DTCs, Air leaks intake and exhaust, stuck/leaking EGR.
- Year and Model: 855, 1995
- Been thanked: 2 times
There is no CEL. I will check the DTC anyway. Exhaust manifold was replaced a while ago due to the flex elbow leak. EGR was replaced years ago when I did the PCV replacement. How to check air leaks in intake, exhaust and EGR valve ?
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
- misha
- Has thanked: 73 times
- Been thanked: 186 times
A6?
Being a '95 it should have Jetronic LH 3.2 management will can have 2 separate ecu(s),one for engine and the other for ignition.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Just went out to check for A6 DTC. There was no code, meaning, no LED lighted up in A6 socket. I had tried 4 times, no LED light up. I could see the female connector inside A6 hole, but just no LED light up when compared with A1, A2, etc...
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
- RickHaleParker
Volvo 850 modules and Flash codes. Smoke injection is the best leak detector. You can use starting fluid on the intake side of a running engine for leak detection. When a leak sucks in starting fluid you will hear the engine surge.
- misha
Open up ecu box.
If it's Jetronic...it will have 2 ecu(s) in ecu box....for a car with manual transmission and 3 ecu(s)...for a car with automatic transmission.
That said...
-2 ecu for engine and ignition for a car with manual transmission
-3 ecu for engine,ignition and TCM(transmission control module) for car with automatic transmission.
That said...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Thank you for the information. If it is not Jetronic then it will have 2 modules (Engine & TCM); is that correct ?misha wrote: ↑Fri Jun 19, 2020 1:16 am Open up ecu box.
That said...
Thanks,
Ching-Ho Cheng
- 25 Replies
- 1299 Views
- 14 Replies
- 2842 Views
Last post by commandoNate
- 25 Replies
- 8204 Views
Last post by wizechatmgr
- 450 Views
Last post by pdr1966sc
- 3485 Views
Last post by 93Regina
