Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
1998 v70 AWD dome light problem, locks problem Help needed
vernsimports
Year and Model: 1998 v70awd
Post by vernsimports »
I am unable to find a list of component numbers [ ie 2/75 or 7/39 ] with actual name of component . 1998 V70AWD
Year and Model: 2001 V70
Has thanked: 140 times
Been thanked: 189 times
Post by volvolugnut »
Are these component numbers from an electrical schematic? They sound like they are.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 42 times
Post by FLXC90 »
That's how those read to me also, pin and connector ids from schematic. What are you troubleshooting ( in mechanical terms)
Current Volvos:
vernsimports
Yes, electrical components . Have 3 issues , interior [ dome light ] does not shut off when doors are closed . Must switch off at dome light .
power door locks do not work with remote . Battery goes dead if left connected for several days .
Battery works fine in my S70 , so not the battery .
I am retired from my VOLVO shop now 12 years, so not a lot of experience with P80 electrical issues .
vernsimports
Dome light assembly works fine in my S70 . Have several proper remotes but none work .
Might add, I have the AUTODIAGNOS MULTITESTER PRO which is what we used at the VOLVO dealership .
Has thanked: 477 times
Been thanked: 1410 times
I dont think the component numbers are preserved across model years, but 2/76 is the lock controller and 3/79 is the antenna ring in 1999. The component family 2/xxx will be preserved.
If you are having trouble with the courtesy lights coming on, there is a painful thread on that in this forum with 2/76 part number in the title.
No children should be in the room while it is being read.
vernsimports
Thanks ! Could the dome light issue and the door locks be connected ? I see several microswitches in door latch . Surely one tells the dome light that the door is closed ?
Everything sends signals to the lock controller, which then grounds the lights through a power transistor
It’s a nasty complex system
vernsimports
Thanks, tried 2/76 thread search , but it was not found . How do I search thread for 2/76 ?
This is for a 1999 so the system is different, but gives an idea of the complexity
viewtopic.php?p=498565#p498565
