I am getting a code for the Right Rear Wheel Sensor. The traction control light comes on and I get a pulsation occasionally when I am braking while driving. What is involved in replacing this sensor? Is this what is causing the pulsation?
Thank You!
1996 850R Code for Right Rear Wheel Sensor
- Been thanked: 15 times
I had this problem 2x.
The first time I replaced the sensor and wiring all the
Way up to the trunk by removing the wire pins
From the yellow harness.
The 2nd time I spliced the sensor in by soldering the
Wires and heat shrinking them. I used ebay sensors because they are ridiculously expensive and any sensor
Will work fine
Will work fine
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
