Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Fuel injectors
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 52 times
Fuel injectors
Post by loveMy850 »
Hi guys, I pulled some fuel injectors out of an 850 yrs. ago at the JY. Mine are in need of a cleaning.if I clean the ones out of the junk yard will I have a tuning problem or should I practice the cleaning on the JY ones and then do the ones that are in my car. I'm a little confused about the fuelinjector tuning and all that,.any helptips will be GREATLY Appreciated. Thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 761 times
Been thanked: 332 times
Post by matthew1 »
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
misha
Has thanked: 73 times
Been thanked: 184 times
Post by misha »
If they have the same Bosch numbers on it and have the same color...it's a direct swap.
But....if they were unprotected all those years....they will need cleaning before install.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
loveMy850
Post by loveMy850 »
Thanks they are a different color and a bit smaller thought I'd practice cleaning them. Do you think those small self cleaning kits for 14$ is worth it. I tried making my own but the darn thing kept coming off on the tire cap I was using. Oh well... TY
misha
Post by misha »
In that case....i wouldn't install them.
You will need injectors with same Bosch numbers and color.
They may have higher or lower flow rate...different resistance....and engine would not run properly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 42 times
Post by FLXC90 »
So yeah, if a 14 dollar kit allows you to practice before you tackle your primary set, spend and tear 'em down and build 'em up a couple times, then do it for real on the set that came in your car. Or have them commercially serviced. Depending on where you are in CA may be easy and cheap(ish)
Current Volvos:
loveMy850
Post by loveMy850 »
Agree.... I'll do it myself, I did however pulled my injectors and cleaned them, not inside but I took a soft brass brunch and cleaned the tips, lots of carbon build up. Just doing that my babys feel much better... ( :
