Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Radiator fan
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 52 times
Radiator fan
Post by loveMy850 »
Look guys I'm having a problem with my fan not coming on sometimes it does. It's like when I jiggle the relay or the sensor wire. Granted I'm impatient. I just got this New senor and new relay. I put an older relaybackin then I jiggled the sensor.then tappe the relay and it came on. Then down the road doesn't work.what the hexk is going on.
jlp920
Year and Model: '96 850, '95 940
Has thanked: 5 times
Post by jlp920 »
Are you using the old relay or the new relay?
misha
Has thanked: 73 times
Been thanked: 184 times
Post by misha »
Ect sensor and it's relay MUST be oem.
If you bought aftermarket sensor and relay this is expected.
Also check wiring on a relay and ect sensor from wiring loom side.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 22 times
Been thanked: 317 times
+1 on what misha says. Only Volvo unless you are in Europe where you may find the OEM supplier parts like Vernet for the ECT.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
loveMy850
Post by loveMy850 »
Well I found an old volvo relay in my stuff I put it turned AC, came on for a bit. Shut it off turned AC iback on nothing. I think this old one is bad. At the JY found another, went ahead and got it. Will try that. kinda broke right now but I ordered a used guarantee to work on eBay. Yeah the one I bought was not volvo. My volvo is stubborn if it's not volvo I think she gets pissed off. A little bit.
misha
Post by misha »
Ac doesn't work that way in these cars...especially if the car is equipped with ECC.
Cooling fan will not turn on when you hit ac button,unless you turn the heater blower on and ac compressor is engaged.
If ac compressor is not ON because if it is low on freon,or seized...cooling fan will not turn on when you hit ac button and heater blower.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
