so many problems Topic is solved
riank
so many problems
my 2004 xc90 is causing a lot of trouble. first the brakes had to be replaced after showing very deep cuts on the disc. then the rear parking sensors wouldn't work, because of a technical failure. 2 weeks later the buttons on the steering wheel, controling the volume of the radio did not work and now the xc 90 is getting the rear left suspension repaired. it is very annoying, because it is only 7 months old. it seems that the xc90 has much to improove conceirning its quality. is it true that the xc90 is beeing produced in spain and not only in sweden?
FromSpain
I have an XC90 here in Spain and no problems so far...Are you suggesting that your problems could be related to an imaginary spanish-made XC90? You
yeagermeister
- Year and Model:
did you buy your XC90 new? does your state have a "Lemon Law" (if you're not in the U.S., where are you?) check here for more info if you're in the U.S.
seems like a lot of problems in a short period of time. if everything is still under warranty and you're not paying out-of-pocket for all of these repairs, at least you're not taking a financial hit, but you're still without a car for some period of time...
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
'94 855 5-speed
- 573 Views
Last post by lingon300k
- 1508 Views
Last post by precopster
