Stumped: 2013A XC90 angle gear without d&f port... Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
...or am I not looking hard enough.
Diagram shows item #9.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Angle gears associated with the TF-80SC have the drain fill either on the back or on the side. My old angle gear in the V8 had it on the rear (fluid swap was a complete PITA, got scars to prove it). When I replaced with OE exchange in 2016 (new PN with some added parts), I noted that the drain/fill is back on the side.
It's there, might have to crawl around a bit to see it.
xHeart
Post by xHeart »
The diagram below shows a port just above the bolt location #16.
It is a plug with copper gasket, but one problem. The port opening is blocked with metal wall.
ggleavitt
Post by ggleavitt »
Maybe best to do an image search for Volvo 31325886 or Volvo 36002052, lots of photos which show both of the locations.
Not following the "blocked by metal wall" comment, a short section of the exhaust passes in front of the side fill hole and I'm pretty sure if needs to come off if you're doing a fluid change. It does for a V8 if the hole is on the side (as mine is now).
10/23/18 edit- Understand what you mean by metal wall now, the receesed area above #16 does not have a threaded drain plug in your car. Maybe a photo would help if you can do it, if you have a third location for a D/F hole, I for one would like to see it. Rear hole is hard to see, you may have to look from behind the subframe to see it.
xHeart
Post by xHeart »
It is the port for D&F.
The hose was too big of an OD/ID to travel pass the opening -- rigid material too. Narrower hose line 3/8" OD with softer material traveled deep and worked flawlessly.
Instead of using my Mityvac, found this pump https://www.amazon.com/ALEKO-BST1017N-D ... 017n&psc=1 an easier and faster alternate.
Thank you for your quick replies.
ggleavitt
Post by ggleavitt »
Not many posts on 3.2 angle gear fluid replacement, any chance you could do a quick write-up on what and how you did it for the benefit of the forum? And where exactly was the hole, on the side or at the back? I know the 5/6 and the V8 layouts, but never crawled under a 3.2. Photos if you have them would also be great.
Glad it worked out...
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Take a look at this link for 3.2 info on changing the fluid in the power transfer unit
http://www.freel2.com/forum/topic14659-15.html
Note: this is for the Land Rover LR2 with the Volvo 3.2
Thanks
Paul
xHeart
Post by xHeart »
Bevel gear fluid drain and fill port. This photo reference was overdue:
pgill
Post by pgill »
XHeart,
Green Arrow is the drain/fill port.
Red Arrow is the bottom of the Angle Gear.
Note: this only applies to the Angle Gear housing with the side flange that is 90 degrees to the Half Shaft center line
If you have a PTU that is a 45 degree angle to the Half Shaft center line then I have no idea where the drain/fill is.
Note: I drilled a drain hole for mine, getting the tube to the bottom of the Angle gear assembly is very difficult.
https://landroverforums.com/forum/lr2-3 ... nit-82510/
Good Luck
Paul
xHeart
Post by xHeart »
pgill wrote: 18 Feb 2019, 14:57 XHeart,
Thanks Paul.
The port faces green arrow -- next to the axle. It is a 14mm plug.
