2008 3.2 stalls/dies/won't start Topic is solved
xiphosm3
- Year and Model: 2007 XC90 V8 Sport
Re: 2008 3.2 stalls/dies/won't start
Let me know if you were able to fix this as I’m having the same repeated issues.
- dandan
- Year and Model: 2008 Volvo XC90 3.2
- Has thanked: 17 times
- Been thanked: 4 times
I did give up and take it to a local independent volvo tech. Turns out I had the bad luck of installing a faulty fuel pump the last time. So I purchased another and it started right up after they installed it. This will be the 5th fuel pump in this vehicle
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 115 times
- Been thanked: 185 times
Dan^2,
Five fuel pumps!!!!!!!!
That is true dedication.
You need to change your screen name from DanDan to XC90_Dan
Glad to hear that you got it fixed
Take care
Paul
Take care
Paul
- RickHaleParker
- Been thanked: 958 times
Five!
I would be looking for poor grounds that drop the voltage and up the current. The pumps need X amount of power to run. If the voltage drops the current must come up to get the required power.
- Has thanked: 1505 times
- Been thanked: 3818 times
This is sparse data but the take home I get from these is that the
Electronic fuel pump parts >>>>>>> Mechanical parts reliability
It seems like time and time again we troubleshoot waveforms, PEMS. CEMS and then find a kinked line.
Guru jimmy has a great dirt add on in the shockwave thread about how you can go through 5 pumps getting the dirt out of the tank.
- dandan
First fuel pump was the stock pump. The first replacement pump I was unaware of until it fail. Upon replacing the pump I noticed that it had already been replaced. (So 1st pump replaced by me was the 3rd pump in the vehicle.)
3rd pump failed due to user error in installation (kinked line)
4th pump installed great worked for a week and failed.
5th pump replaced by independent shop. Still seems to be running fine!
All pumps installed after original were delphi pumps.
