Coming back from Easter visit Saturday I suddenly get screeching fro the ps pump and little boost at low speed turns more than 1/2 wheel rotation.
Fluid level ok. No leaks underneath.
I ordered an aftermarket ps pump ftom FCP , AAE $350, OE Volvo $1000…. Ouch
Hope it isn’t the rack…
2013 xc90 power steering issue , 3.2 l I-6 [replaced tensioner and idler] Topic is solved
- Been thanked: 4063 times
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
Are those pumps hybrid units with electric and hydraulic system? If yes, where you able to check power and ground to the pump? Also it might show codes if it is hybrid system
Hydraulic pump with electric solenoid control on rack
It’s the pump, got the hood up today and it’s chirping and wheezing with steering neutral, under no load.
New rack not too bad , $1300 oe Volvo
It rolled us home fine from NYC at 27 mpg , will decide it’s a me or indie job on Monday
Well had a look and the idler and tensioner are making the noise.
Hot Volvo oem for about 300 all in, and needed three hours , so sent it to Indy as I left for Paris at noon.
All done and back on the road same day. Thank you, Munch Motors
- 14 Replies
- 3907 Views
Last post by PeteB
- 809 Views
Last post by fixer333
- 9050 Views
Last post by IronMike
- 823 Views
Last post by precisionguesswork
- 1132 Views
