2008 Volvo XC90, 3.2 AWD, Transmission Flush
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Been thanked: 61 times
Re: 2008 Volvo XC90, 3.2 AWD, Transmission Flush
Post by ggleavitt »
http://www.timthurber.com/volvo-xc90-3- ... c-6-speed/ is a good post to review, as is this- https://forums.swedespeed.com/showthrea ... luid-flush
As noted, a TF-80SC is a TF-80SC, no difference between the engines as far as fluid replacement. Step noted for resetting fluid counter after replacement, requires connection to vehicle using a Volvo compatible tool (VIDA/DICE as example).
Some do a full pump-out (I do 16 qts the first time, 12 thereafter), some do drain and fill (3-4 quarts at a time). Either way, transmission takes >8 quartz of fluid (JWS3309 until chassis 568000, then BOT324/JWS3324 for chassis >568001). Changes as noted in viewtopic.php?f=10&t=84764
2005 2.5T AWD-201k
2008 V8 AWD Sport-134k
T5AUS
Year and Model: 08 XC90V8 94 850T5
Post by T5AUS »
Thanks for that BKM
1994 850 T5
2001 V70 T5 (Sold)
2008 XC90 V8
skippyxc90
Year and Model: XC90 3.2 AWD 2008
Been thanked: 3 times
Post by skippyxc90 »
I have a VIDA DICE 2014D. It spits out anything for Volvo vehicles from 1999 to 2014. Give me the model of your XC90 and I'll be glad to generate and post the steps.
You should know that to properly check the trans mission fluid, you must idle until the transmission fluid reaches 50 to 60° Celcius. All excess fluids will overflow and that's where you screw in the Integrated Level Plug bolt.
Without knowing the fluid temp and or not having a VIDA DICE to gauge the temp might give you inacurate result.
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 9 times
Post by Turbo_Boss »
Hey Guys,
I am going to change my ATF Fluid on my 2008 3.2 XC90 and since I am ordering some parts to a Volvo Dealer, I will appreciated if you can help with some part numbers.
I have check the schematic diagram on the Volvo Parts and don`t find the part number for the big and small crush washers that`s goes in the Transmisión Draining Plug: https://pasteboard.co/IJtBdcC.jpg and this: https://pasteboard.co/IJtDhud.jpg
Also need the part Number for the Washer or O Ring that goes in the Filler Plug that`s goes in the top of the transmisión housing : https://pasteboard.co/IJtCzEZ.jpg
Thx for your time and help
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
skippyxc90
skippyxc90
Transmission Drain Plug washer
skippyxc90
The Filler Plug rubber o ring is not critical. The crush washer and the Integrated Level Plug rubber o ring is a "MUST"
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 43 times
Been thanked: 100 times
Post by MoVolvos »
Just in case you need other parts Turbo_Boss.
https://usparts.volvocars.com/Volvo_200 ... ssion.html
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
Post by MoVolvos »
T5AUS wrote: Mon Dec 02, 2019 4:54 pm Thanks for that BKM
Hope it helps T5AUS. Here is someone checking the level without the software (after all the other work).
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Turbo_Boss
skippyxc90 wrote: Tue Dec 03, 2019 12:19 am The Filler Plug rubber o ring is not critical. The crush washer and the Integrated Level Plug rubber o ring is a "MUST"
Hey Skippyxc90,
Thx for the part numbers.
Isaac
2009 VW Jetta 2.0
