Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
2004 XC90 T6 CEL misfire codes very rough idle Topic is solved
- Year and Model: 2003 XC70
Hello, I have a 2004 Volvo XC90 T6. with 100k miles. The CEL is blinking. Checked codes and shows misfire in 1,4,6. I changed, coil packs and same. I changed the spark plugs, same. Changed injectors and same problem persist. If I let it idle, it sounds really rough. I dont know where else to check. Thank you
Reason: No "Help" in titles please. Edited title.
- Year and Model: 850,XC70,XC90,S60,80
- Been thanked: 12 times
Re: 2004 XC90 T6 CEL misfire codes very rough idle HELP Topic is solved
MAF ?? or Vacuum Leak?? Just throwing out some ideas
95 850 Sedan Auto Trans
98 V70 Manual Trans
01 C70 Manual Trans
03 XC70 Auto
04 C70 Auto
06 XC90 Auto (ORE)
06 S80
12 S60
96 850 Wagon Manual Trans (parts car)
98 V70 Manual Trans
01 C70 Manual Trans
03 XC70 Auto
04 C70 Auto
06 XC90 Auto (ORE)
06 S80
12 S60
Is there a certain procedure to check the MAF? Also, how would i go about performing a vacuum leak test? aside from visually inspecting. Thank you
First...all advice below... is at your own risk since I have not done them on the XC90... but here is what I have done on my other cars to test MAF. Unplug it and if car runs the same then it is the MAF thats bad.
Vacuum lines Start with visual and audible for the vacuum lines. There are ways to test vacuum with a tester or with smoke or with carb cleaner spray but you would have to research those yourself (youtube) or maybe someone else could weigh in on that stuff... and you decide if that's what you want to do. With carb cleaner I believe if you spray by a leak car will run better or worse for that second while the spray is there hence indicating a leak.
98 V70 Manual Trans
01 C70 Manual Trans
03 XC70 Auto
04 C70 Auto
06 XC90 Auto (ORE)
06 S80
12 S60
98 V70 Manual Trans
01 C70 Manual Trans
03 XC70 Auto
04 C70 Auto
06 XC90 Auto (ORE)
06 S80
12 S60
