Understood. I've seen bad ones not register codes before.
Is there a best practice for looking for spark. I know in the old days you could just hold up the plug to ground but I'm seeing posts/videos about damage to coil.
Thanks. That test makes sense...I've just seen a lot of guys claim one can damage the direct ignition module this way...but I have always been skeptical.jimmy57 wrote: ↑Tue Sep 04, 2018 8:30 pm Yes, you can check for spark by putting a spark plug into coil boot and then laying the plug threads on head or other engine metal for ground and then cranking it over a few revs. Since it is individual coils the spark will seem infrequent if you check just one. Did you try cranking with it floored? If it's flooded it might be reluctant to go.
Thanks for the input...I don't doubt this at all. I think from my reading (and theories) doing a battery disconnect and touching the +/- to dissipate any residual power in modules would have a similar effect. Will consider it all as it sure seems like it may have "stored" some type of concern...just surprised Vida doesn't log anything at this point! I've had many a Volvo with bad direct ignition modules not leave a single code in Vida, so not surprised this time. But just scratching head on what it still could be in light of the found bad coil.RickHaleParker wrote: ↑Tue Sep 04, 2018 8:58 pm I recently changed a jumped timing belts on a 1.9L. After the belt change it would not start. Disconnected the camshaft postition sensor, it took a extended crank but eventually the ECM got it started using the lookup tables. After that it starts right up with the CPS connected.
You might try disconnecting the CPS or MAF and force the ECM to rethink. The ECM has some AI code in it, sometimes you got to play with it's mind to get it out of a mind set.
