IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Driver seat going up and down without moving controls. Just recently my seatback is moving back to a reclining position.
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Ruth4149
Year and Model: 2008 xc90
Post by Ruth4149 »
I have a 2008 xc 90, fwd. The driver seatback goes up and down for no reason. Sometimes it will go back up to its upright position, and sometimes stays reclined... Obviously this is a frustrating problem... Any answers?
SuperHerman
Been thanked: 174 times
Re: Driver seat going up and down without moving controls. Just recently my seatback is moving back to a reclining posit
Post by SuperHerman »
Couple questions: 1) Does movement happen while car is actually moving or does it happen at start up? If at start up it is most likely a key FOB related memory function. (Did you change key FOBs or going back and forth between two FOBs?)
Question 2) Are you wearing or carrying anything (like a longer coat - too much junk in the door pocket) that may be interfering with the controls?
Question 3) Look at the plastic cover where the seat controls sit - give it a slight pull in various directions to see if it has any play. It should be firmly in place. On my 2004 XC90, on the passenger side, my niece managed to somehow dislodge mine and it blew the fuse. Upon removal and inspection I found a shorting wire which needed repair. Once repaired, installed and fuse replaced no more issues.
If none of these items are suspect it could be a faulty module or some other wiring issue which needs trouble shooting. I suppose as an interim fix you can adjust your seat to where you like it and pull the fuse for that seat.
Ruth4149
Post by Ruth4149 »
Thank you so much! Great advice- I’ll try these things. Not #1 or 2, so going to try #3 info and check fuses... 🙂
darrylrobert
Year and Model: 2001 v70xc M58
Has thanked: 3 times
Been thanked: 20 times
Post by darrylrobert »
A FWD xc90 didnt know that existed? No wait front wheel drive or four wheel drive..
In coronavirus lockdown going through posts, sounds like an interesting issue i wonder what it was?
2001 XC70 factory M58
2002 XC70 auto (parts car)
