XC90 Key transponder failing.
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
donnymol
Year and Model: 2012 xc90
Post by donnymol »
I have seen that others have this issue as well. My car is 2012 xc90. It intermittently wouldnt start, but last night and this morning i am having no luck. The dealership is telling me its about $400 for a new key + tow. Has anyone else found a more reasonable solution?
Been thanked: 163 times
Re: XC90 Key transponder failing.
Post by cn90 »
Happened to my 2005 XC90 key.
Keep the FOB, if you replace ONLY the key portion, then about $250.
I posted some info in forum.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Been thanked: 61 times
Post by ggleavitt »
As a point of clarification, engine turns over with the key but does not start or does not turn over at all? And you have only one key so cannot compare against another?
2005 2.5T AWD-201k
2008 V8 AWD Sport-134k
donnymol
Post by donnymol »
yes. i only have the one key.
no, the engine does not turn over. i get the error of start failed, try again.
someone in my IT departmment thinks the circuit may be damaged. they are gonna try and check it today and see.
Post by cn90 »
Do you have a second key, which makes diagnosis very easy.
This was my case...I used the second key for diagnosis.
donnymol
Post by donnymol »
Yea, just the one key. I am pretty sure its the key/circuit/transponder. I am just seeing if there is another solution rather just buying a new key from the dealership
hebhere
Year and Model: 2005 xc90 tr6
Post by hebhere »
Both of my Key Fobs need programmed. The key works, not the remote. I do have a Valet Key also, which is what I use. At the my friend's shop, where I help him at times, we can get every key re-programmed for about $100.00, some we are able to do ourselves. But, not the Volvo Key Fob......Nope, Volvo has that locked in. I was told by the dealer $350.00 per fob. What is bad is it only takes a few minutes to do.........Been living with it this way..... Will continue to do so unless I win the lottery.
yagger
Year and Model: S60 2005 2,5T
Has thanked: 6 times
Been thanked: 29 times
Post by yagger »
We can unlock remotes. After this procedure you can program it to car, use official VIDA or we can program it use our own methods.
jimmy57
Been thanked: 275 times
Post by jimmy57 »
By any chance does the key NOT stay latched 180 degrees from the folded stored position? If the key doesn't stay latched then the chip can be out of range when the remote folds over at 90 degrees to key.
