Amazon Black Friday deals
2013A XC90 - 150,000 Miles To-Do List
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 27 times
Been thanked: 47 times
Re: 2013A XC90 - 150,000 Miles To-Do List
Post by xHeart »
Found following Axle Ping description at the IPD parts website:
The sound tends to be more of a clank or clunk sound but the sound can potentially echo down the axles some situations and make a more harmonic sound, hence the "ping" moniker.
Axle ping is most apparent when you shift the car from reverse to drive and back again with your foot on the brake. There will be a noticeable clank noise upon the shift in directional load against the drive train. This is easier to produce on automatic models but the same applies to manual transmission models.
https://www.ipdusa.com/techtips/10185/a ... s=P0,P6251
I replaced front axle screws and the "axle ping" is gone.
FWIW: VIDA has two torques specs for each type of screws, i.e, with cone and without. Without cone screw is 2 stage torque, 35Nm and then 90º stretch. With cone, it is straight 50Nm.
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km | 1997 Volvo 850 +180mi/289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
xHeart
Post by xHeart »
A recent look at the 2013A XC90 profile in VIDA, it shows the Service Schedule II for 150,000 miles. I'm on track!
It lists Coupler - the belt connecting alternator and decoupler pulley as a serviceable item. Can it wait another 50,000 miles? What about the decoupler pulley, and the alternator?
Also, what to look for before refreshing the various engine mount, which one fails?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 26 times
Been thanked: 46 times
Post by pgill »
For my 2008 LR2 the Alternator Over Drive Pulley had failed prior to 150,000 miles.
When it failed it stopped the Alternator from Freewheeling but it didn't have any noticeable detrimental effect.
I replaced it as preventative maintenance but I didn't know that it had failed until I removed it.
I didn't replace the belt, I only replaced the Overdrive Pulley.
I think if you let it go long enough with the Freewheel function not working then you run the risk of the bolt that holds the pulley for the READ side backing out and the Alternator stops charging.
Let us know what you decide to do.
For my 2010 S80 the Alternator had been replaced some time before I bought it so I haven't changed that pulley or coupler (Maybe at 200,000 miles)
Take care
Paul
xHeart
Post by xHeart »
pgill wrote: Fri Nov 06, 2020 12:26 pm For my 2008 LR2 the Alternator Over Drive Pulley had failed prior to 150,000 miles.
Take care
Paul
A recent experience with our 2001 V70XC intermittent voltage raised the awareness that the generator OAP pulley too has limited life - CEM:0C01. A refreshed alternator may be good for few more years.
The coupler and the alternator pulley are now added my to-dos –– Volvo Alternator Decoupler Hub Coupling Kit - INA 5350175100
