value brands for 2005 CV axle? Topic is solved
850TurboTurtle
- Year and Model: 96 850T, 05 S80T6
- Has thanked: 10 times
- Been thanked: 5 times
Hi - I need to replace my drivers side CV axle on my 05 T6 S80. I'm looking at 5 more years from this car, and hoping to avoid $350 for the part. But I know there are cheap chinese knockoffs that fail quickly. Any recommendations on reliable parts for light use at a decent value??
- SuperHerman
- Been thanked: 207 times
If you are handy you can reboot yours. If you cannot afford the downtime and/or yours cannot be rebooted b/c it is destroyed and you are handy you can buy a nice condition used one and reboot it as preventive measure. Once you have it rebooted and ready to install you can pull yours and swap. In and out and done.
If you can afford the downtime I would just reboot yours - take it off - pull the old boots (try to keep the clamps in the best condition you can as sometimes they have to be reused (don't use a ziptie)) and examine the condition of the internals. If they pass then reboot both sides and reinstall. It is a messy job, but fairly easy. The hardest part is taking the CV out. Site sponsors should have the reboot kits.
A used OEM part or the original rebooted will provide you the best experience and is a known commodity.
