IPD sale Volvo Parts
2004 S80 shifter knob broken how to remove shifter
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
ictshocker
Year and Model: 2004 S80
United States of America
Post by ictshocker » Mon Sep 04, 2017 8:53 pm
Geartronic shifter with knob that has center pin. Plastic broke around pin. Trying to figure out how to remove shifter so that I can replace the knob/trigger.
Videos I have found for other model Volvo's of same year seem to indicate that you must just pull up really hard on the shifter to remove it. Is this correct? Also has a leather skirt around base of shifter.
This is an automatic with T5 engine, 2 wheel drive.
Thanks!
quietlymknnoise67
Year and Model: 2003 C70
Re: 2004 S80 shifter knob broken how to remove shifter
Post by quietlymknnoise67 » Tue Sep 05, 2017 3:48 pm
Twist boot ring connecting boot to the knob to release it from boot then pull straight up on knob very hard. It will come off from stem.
oragex
Year and Model: S60 2003
Has thanked: 61 times
Been thanked: 77 times
Canada
Post by oragex » Tue Sep 05, 2017 4:55 pm
These is how it goes on my S60, just detach the boot first as mentioned and watch your fingers
2003 2.4i S60 automatic 125k miles
ictshocker
Post by ictshocker » Wed Sep 06, 2017 7:07 pm
Thanks!
So same process for s60 and s80.then? Do I need to have trigger pushed in when pulling up? Button is gone so hoping not.
Any recommendations on disconnecting boot? I've twisted clockwise and counter to no avail.
Thanks!
quietlymknnoise67
Post by quietlymknnoise67 » Thu Sep 07, 2017 7:18 pm
After twist, push down on boot material. Pull up on knob hard. The whole thing will come out. Pry out button with flat blade and when you install it back work the slide onto the button stem.
oragex
Canada
Post by oragex » Sat Sep 16, 2017 11:30 am
edit
Who is online
Users browsing this forum: No registered users and 17 guests
