IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
S80 T6 lacks power
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
Loddzz
Year and Model: S80 T6, 2003
Has thanked: 0
Been thanked: 0
Sweden
Loddzz
Re: S80 T6 lacks power
Post by Loddzz » Tue Apr 30, 2019 5:34 am
I Will do a new reading on the Fuel trim when i’ll get Home from work, and also try to unplug the BPS.
Yesterday i took the whole intake manifold off and put it back with new gasket, cleaned the throttle body, cleaned the TCV, changed more vacuum hoses under the intake manifold, and checked all other hoses and tubes(again).
But still, no change....
I can’t find any air leaks at all
Loddzz
Has thanked: 0
Been thanked: 0
Sweden
Loddzz
Post by Loddzz » Tue Apr 30, 2019 10:48 am
Okay so, i did a new 5 min live logging, at idle and with warm engine.
Fuel Trim Short/Long term, B1/B2
Throttle Position
Mass air flow
Intake air temp
Throttle Position
And here´s a video of how the car acts on Kick-Down
https://www.youtube.com/watch?v=MZeuYOZEsXY
Loddzz
Has thanked: 0
Been thanked: 0
Sweden
Loddzz
Post by Loddzz » Tue Apr 30, 2019 12:02 pm
It seems like i’ve found what was wrong.
I disconnected the TCV and took it for a test drive. It lacked the power(of course), but it went smooth on Kick-Down.
So i guess the TCV is the bad Guy here
SuperHerman
Has thanked: 0
Been thanked: 118 times
United States of America
SuperHerman
Post by SuperHerman » Tue Apr 30, 2019 2:24 pm
From what I have read they do get "lazy" with age. I have heard some having luck spaying cleaner in there a few times. As it is failed/failing and you intend on buying a new one it cannot hurt. Easy enough to try, but for the price of a new one I would just replace it.
Your fuel trims still look too high. If you are certain you have no air leaks, I would try some injector cleaner in the gas a few times. Cheap enough and would address dirty fuel injectors if that is the cause. Basically you may be getting a dribble rather than a spray.
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 17 times
Been thanked: 22 times
Netherlands
ndphotonl
Post by ndphotonl » Wed May 01, 2019 12:17 pm
Yep, your long term fuel trim should be between -10 / +10%. If you are buying a new TVC, then buy this one > viewtopic.php?p=503746#p503746
There is an easy test you can do with your TCV, blow through the top hole or rear hole (cant remember which one exactly), it should flow quite freely.
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
Loddzz
Has thanked: 0
Been thanked: 0
Sweden
Loddzz
Post by Loddzz » Mon May 06, 2019 4:58 am
Well, my Volvo had an accident last friday... :(
ndphotonl
Netherlands
ndphotonl
Post by ndphotonl » Thu May 23, 2019 8:52 am
Regarding fuel trims, they should be between -10% / +10%. The short term fuel trim might fluctuate a bit more which is ok. The most important is that the long term fuel trims are between -10% / +10%.
If these values are excessive, then you have a problem (like vacuumleaks etc etc)
Cees Klumper
Year and Model: C70 2008 T5
Has thanked: 8 times
Been thanked: 4 times
Cees Klumper
Post by Cees Klumper » Fri May 24, 2019 5:55 am
On my T6 I also had an issue similar to yours: hesitation at full-ish throttle. I replaced the TCV itself and the problem was solved. Definitely worth a shot IMO.
ndphotonl
Netherlands
ndphotonl
Post by ndphotonl » Fri May 24, 2019 7:20 am
Tip, save some money and buy the "HD TCV" which is a Pierburg unit which is used on Porsches & Rovers
ImageVolvo S80 2.4T Pierburg TCV 7.22908.03.0 by ND-Photo.nl, on Flickr
Kjmike95
Year and Model: 2004 S80 T6
Has thanked: 1 time
Been thanked: 0
Kjmike95
Post by Kjmike95 » Wed May 29, 2019 7:52 am
By any chance have you checked your boost? I'm having a similar issue and my boost readings are odd. My obd has a setting to read it.
