IPD sale Volvo Parts
Did you know? 🤔
Tire size
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
MPOOL
Year and Model: 2006 S80
Has thanked: 0
Been thanked: 0
United States of America
MPOOL
Tire size
Post by MPOOL » Sun May 05, 2019 2:41 pm
I recently purchased a 2006 S80 with 17" tires. Prior to that I have been driving a 2004 S80 with 16" tires. Both are front wheel drive 2.5T s. I like the feel of the 16" wheels better than the 17" ones. Also I had just bought tires for the 2004 before it became too expensive to fix. I would like to put the 16" tires on the 2006 which now needs tires. I get mixed messages from tire sites about doing this. Has anyone had any experience with this ? I understand the question of fit re rotors and brakes comes in but maybe that is hopefully a non issue. Thanking you in advance for your thoughts.
Year and Model: Lots
Has thanked: 4 times
Been thanked: 94 times
Australia
Re: Tire size
Post by precopster » Sun May 05, 2019 4:06 pm
If the front brakes on the 2006 are larger than the 2004 there may be a problem.
As you haven't given the actual sizes I can't comment on the difference and possible impact to the speedometer calibration.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
MPOOL
Has thanked: 0
Been thanked: 0
MPOOL
Re: Tire size
Post by MPOOL » Mon May 06, 2019 3:20 pm
The front brake rotors are the same size on both years. Same bolt pattern also.
Tire sizes 2004 215/55R 16
2006 225/50R 17
Thank you for your knowledge about this.
quietlymknnoise67
Year and Model: 2003 C70
Has thanked: 0
Been thanked: 0
quietlymknnoise67
Re: Tire size
Post by quietlymknnoise67 » Mon May 06, 2019 3:44 pm
Alt tire size 235/45r17
Australia
Re: Tire size
Post by precopster » Mon May 06, 2019 6:17 pm
Tire diameter of a 215/55/16 is 643mm and is correct size for a 2004 S80
Tire diameter of a 225/50/17 is 647mm and is approximately 0.62% larger
Both sizes are in the 2006 owner's manual so should be OK for the 2004 if brake size is not an issue
RickHaleParker
Has thanked: 3 times
Been thanked: 305 times
RickHaleParker
Re: Tire size
Post by RickHaleParker » Tue May 07, 2019 12:54 am
Tire circumference is -2.3% shorter. The speedometer would be off -2.3%.
Unless the ECM was re-calibrated to the new tire size.
At a indicated speed of 70 MPH. The car would be moving 70 mph * .977 = 68.39 mph.
Looking through the dimension. If you have a rubbing problems, it is most likely the offset of the rims.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
MPOOL
Has thanked: 0
Been thanked: 0
MPOOL
Re: Tire size
Post by MPOOL » Tue May 07, 2019 5:49 am
Thanks for the workup. I am going to go with the 16 s . I'll let you know. Thanks again.
