IPD sale Volvo Parts
Did you know? 🤔
Two replacement ETMs installed in last 10k miles. Still surging?
Do you have a failing Electronic Throttle Module? What steps to take if you do, plus the latest ETM news. Volvo 1999-2002 models only please.
briangtbc
Year and Model: 1999 V70 T5
Has thanked: 1 time
Been thanked: 0
United States of America
briangtbc
Post by briangtbc » Thu Feb 21, 2019 7:54 am
I picked up a 1999 V70 T5 last week on eBay. A buddy with a 1999 V70 T5 warned me about the ETM issues and suggested I make sure this wasn't an issue with this car. The seller self-installed a rebuilt ETM just before selling the car at 177k miles. Looking through the extensive service records that came with the car, I noticed another owner of the vehicle had the ETM replaced at 167k miles.
Currently, I'm experiencing surging of the throttle, primarily when in gear in either R or D, occasionally while in P. No ETS or Check Engine service lights are on.
The seller has a contactless throttle body sensor kit that he purchased and installed prior to the latest ETM replacement, hoping that would fix his issue. But when it didn't, he removed it and just replaced the ETM. Right now, the plan is to remove the ETM and install the contactless sensor. I'm hoping that will fix the surging, but I'm worried about this car having two new ETMs so recently and still experiencing the surging issue. Any other things I should check before getting into the ETM?
Current: 1999 V70 T5
Former: 2006 V70R 6MT
RickHaleParker
Has thanked: 3 times
Been thanked: 303 times
RickHaleParker
Re: Two replacement ETMs installed in last 10k miles. Still surging?
Post by RickHaleParker » Thu Feb 21, 2019 6:00 pm
Get a Diagnostics Scanner and get better diagnostics info. A DiCE clone and Vida 2014D_RePack is recommended.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
briangtbc
Has thanked: 1 time
Been thanked: 0
briangtbc
Post by briangtbc » Sat Feb 23, 2019 9:30 pm
Grabbed an old OBD scanner I had and pulled P1238 code. Research says that is related to turbo control valve. Possible vacuum leak or bad TCV?
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sat Feb 23, 2019 11:11 pm
P1238 = ECM-6806 Turbocharger (TC) control system flow fault. Flow too low or too high. Permanent/Intermittent fault
Diagnostic trouble code (DTC) information
Condition
If engine speed (RPM) is above 3500 rpm and the engine is operating at a high load, the control signal to the turbocharger (TC) control valve is at maximum and the boost pressure (from boost pressure sensor) is lower than a designated value (approximately 20 kPa (2.9 psi) under normal boost pressure - signal too low).
If the air mass (from mass air flow (MAF) sensor) is higher than a desired value (signal too high) it is interpreted as a fault and diagnostic trouble code (DTC) ECM-6806 is stored.
Substitute value
reduced boost pressure
Possible source
Signal too high:
  • 1. air leakage after turbocharger (TC)
Signal too low:
  • 1. hoses between turbocharger (TC) and turbocharger (TC) control valve respectively turbocharger (TC) control valve and pressure servo are loose or are blocked/damaged
    2. faulty turbocharger (TC) control valve
    3. faulty boost pressure control (BPC) valve pressure servo
    4. sticking boost pressure control (BPC) valve
Fault symptoms
none
These users thanked the author RickHaleParker for the post:
briangtbc
Has thanked: 185 times
Been thanked: 560 times
Trinidad & Tobago
Post by abscate » Tue May 14, 2019 4:56 am
Flippers will try to fix the car long enough to sell it to the mark with a cheap fix. Just cleaning an ETM can get you a few weeks of operation , enough for the seller to justify the year fixed it.
History check on any car is paramount, and if the seller hasn’t transferred title, assume you need a $1000 ETM and take it off wholesale price.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
