IPD sale Volvo Parts
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
1994 460 GLE: Light bulb dash symbol
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
RiKardo94
Year and Model: 460 1994
Has thanked: 0
Been thanked: 0
RiKardo94
Post by RiKardo94 » Thu Apr 28, 2011 8:23 am
Hi everyone! I have a question about a symbol on my dashboard. Its an orange symbol, showing one of my light bulbs are blown, but when I press the brake pedal, it dissapears. Is that normal or is there a way to fix it?
Thanks in advance, folks!
Richard
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Re: 1994 460 GLE: Light bulb dash symbol
Post by billofdurham » Fri Apr 29, 2011 12:14 pm
This is normal on the 4 series. It is a check on the bulb failure system.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
RiKardo94
Has thanked: 0
Been thanked: 0
RiKardo94
Post by RiKardo94 » Fri Apr 29, 2011 12:28 pm
Ok, I was worried for a bit there.
Thanks for clearing that up, Bill!
Richard
Skinkehunden
Year and Model: Volvo S60 T5 2005
Has thanked: 0
Been thanked: 0
Skinkehunden
Post by Skinkehunden » Thu May 26, 2011 7:26 pm
You should also be aware, that installing two bulbs with different wattage (e.g. rear-light bulbs) can trigger the bulb failure even if you visually can't see any difference upon expecting the car.
skinkehunden
Current: Volvo S60 T5 2005 150.000 km on the clock.
- Volvo Volvo S60 2.4 2006 with 204.201 km on the clock.
- Volvo 440 Pacific 1.8 1995 with 258.197 km on the clock.
- Volvo 440DL 1.8 1992 with 268.500 km on the clock.
- Ford Escort 1.3 1977 with 64.000 km on the clock.
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Fri May 27, 2011 12:10 pm
The bulb failure sensor works on pairs of bulbs and will detect any difference in wattage, one bulb out with the other working and can also detect differences in the age of the bulbs so it is advised to always replace them in pairs. One other bit of advice, never put a silver capped bulb with a bronze capped bulb as the sensor can pick this up and give a false signal.
Bill.
Previously:
QuirkySwede
Year and Model: 1998 S70 GLT
Has thanked: 0
QuirkySwede
Post by QuirkySwede » Tue Feb 25, 2014 1:07 am
billofdurham wrote:The bulb failure sensor works on pairs of bulbs and will detect any difference in wattage, one bulb out with the other working and can also detect differences in the age of the bulbs so it is advised to always replace them in pairs. One other bit of advice, never put a silver capped bulb with a bronze capped bulb as the sensor can pick this up and give a false signal.
Bill.
That and more...
"Volvo Bulb Guide and Cross-Reference"
http://www.matthewsvolvosite.com/forums ... =1&t=61483
On older vehicles with more than one owner, heck even if one owner, not uncommon for someone to install the wrong bulb (see part 1.) leading to the mismatch situation billofdurham described. The sensor/module can work in different ways, but usually it's when the affected circuit is activated (park, turn, brake, etc.), though some may come on if brake lights on both sides are out.
So for anyone getting that dash indicator, the two simple things to do are to note when it comes on, and check to make sure bulbs are the correct ones and matched.
