IPD sale Volvo Parts
Did you know? 🤔
B20b
All the classics... pre-1975 Volvos.
1970145swagon
Year and Model: 1970 145s
Has thanked: 0
Been thanked: 0
United States of America
1970145swagon
B20b
Post by 1970145swagon » Sat Mar 09, 2019 4:23 pm
Hi me and a friend of mine have a 145s with a b20b in it. It has been sitting for 20 years. The motor was rebuilt then it sat. We cranked it over and it dumped oil at the back of the engine. We thought it was a rear main seal but when we pull the flywheel off. There's a little hole in the back of the block of the engine. it's above the crank and to the right of it. that leaks all the way down the back of the engine. Does anyone know what that is and what I'm supposed to put in there to prevent it from leaking? Any help would be be appreciated.
RickHaleParker
Has thanked: 3 times
Been thanked: 296 times
RickHaleParker
Re: B20b
Post by RickHaleParker » Sat Mar 09, 2019 5:25 pm
It just missing a plug. You can download the Service Manual for the B20B here.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
1970145swagon
Has thanked: 0
Been thanked: 0
1970145swagon
Re: B20b
Post by 1970145swagon » Sun Mar 10, 2019 7:49 am
so i can you put in any pug as long as it fits? any way thanks for answering.
RickHaleParker
RickHaleParker
Re: B20b
Post by RickHaleParker » Sun Mar 10, 2019 9:03 am
As long as it fits and clears the flywheel. Go for a length that does not extend above the top of the hole. You might want to match the material so that you don't get Galvanic corrosion between the plug and the block.
Does this look like the correct plug? Aftermarket - Oil Galley Plug - B18 B20
1970145swagon
Has thanked: 0
Been thanked: 0
1970145swagon
Re: B20b
Post by 1970145swagon » Sun Mar 10, 2019 9:44 am
looks good to me. thanks for all you help!
jimmy57
Has thanked: 1 time
Been thanked: 133 times
jimmy57
Re: B20b
Post by jimmy57 » Sun Mar 10, 2019 4:09 pm
It has been a long time but I think that is a 1/4 NPT plug (tapered threads called National Pipe Thread). The thread diameter is way larger than the dimension in the thread name. The size is for ID of iron pipe so the 1/8NPT is about 7/16 inch, 1/4NPT is between 9/16 and 5/8 inch, 3/8 NPT is about 11/16 inch hole.
93Regina
Year and Model: 93:240/940
Has thanked: 0
Been thanked: 34 times
93Regina
Re: B20b
Post by 93Regina » Tue Mar 12, 2019 11:40 am
Your link is in-op, here's the index
