high resistance at fuel pump/engine control fuse number 11. Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jhale
Post by jhale »
740 Turbo Intercooled; When engine starts,smoke can be seen coming from fuse box at that location. How do I locate the developing short & fix the problem.(Fuse box melting at that location#11,enging control/fuel pump.
Volvord
Year and Model:
Post by Volvord »
The first place I would look is at the fuel pump relay, these are known to fail and if the relay contacts are corroded the symptoms could show up at the fuse box. Although the electrical system in 700 series is usually very reliable I would trace the fuel pump circuit (is is quite short) and check and clean all the contacts.
Volvord 784VC
http://www.telusplanet.net/public/gilesij/Volvord/
