740 only runs > 3,000 rpm
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
steveb455
Post by steveb455 »
I'm considering to purchase a nieghbor's '87 740 turbo sedan. It starts, then suddenly quits. Will do this over and over. If I pump the gas pedal and keep the rpms >3,000, it seems to run great and smooth. As it warms up after a few minutes, it will run at about 2,500 rmp, although a little rough. Any slower than that and it dies. Help???
M Jarve
Year and Model:
Post by M Jarve »
My guess would be either low fuel pressure or bad AMM. Maybe look at the throttle position sensor too. A B230FT should idle at <1000 RPM once warmed up.
/Mike
1991 940 Turbo
steveb455
Post by steveb455 »
Thanks M Jarve! I unplugged the MAF (same as AMM I believe) and it started and ran great, but at 2K+rpm. :D If I plug the MAF back in, it starts and immediately dies. Time for a new mass air flow sensor.
